Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
I can see my files in a directory but not able to copy, delete or move or even play. Says you don't have permission to do the task.
  • 1 more comment
  • ranjan007 Dec 23, 2008
    Let me tell you the problem history. I had win vista previously. I copied some files into a directory and hide the folder. After some time, I degraded to XP. When I opened my passport drive, I saw a green folder. Ok till now, I could copy files but not able to get previous files. And history repeats itself everytime I reinstall my XP. Well the thing is...is there any way to access those older files?
  • Anonymous Dec 23, 2008
    Still I am working on vista with my passport drive in my office. I am not able to get those files and getting the same problem. I think, the passport drive will need the same username to access those files. Thanks for your reply. Will certainly help me. Will comment again if I succeed.
  • ashconl Jan 08, 2009
    does it work the opposite way as well? if i copied the files on xp, but then upgraded to vista??
    President:
  • 1,179 Answers
Log on in the system administrator account. This should allow you access to all functions. Hope this helps.
Posted on Dec 23, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 23, 2008
    If you saved the files using Vista then XP will not allow access, only Vista will. Sad to say but only way to access them is if you reinstall Vista and open them. Hope this helps.
I'm Making a batch File that moves and copy files, not working.
@Echo Off
:start
set /p 1=Please Enter Directory and Name of file you would like to move
set /p 2=Please Enter Directory of where the file will go
set /p 3=please select 1 of 2
options 1: copy 2: move
if %3%==move goto a
if %3%==copy goto b
:A move %1% %2%
goto c
:B copy %1% %2%
:C echo end
Apr 26, 2010 | Microsoft Windows XP Home Edition
NO PERMISSION TO EDIT OR VIEW As an administrator, I thought I have all the privileges to edit, view read, modify, execute and write any folder, but on certain folders I must first grant myself the...
you need to Take ownership of those files...
For Files:
takeown /f file_name /d y
icacls file_name /grant administrators:F
For Folders or Directories (will perform action recursively):
takeown /f directory_name /r /d y
icacls directory_name /grant administrators:F /t
Replace file_name or directory_name with actual file name or folder name, with path when applicable. The first command will take ownership of the file or folder specified, and the second command will grant full control permissions to administrators user group. Note that when using command for folders, to command will run recursively. To prevent the task been perform recursively, remove the “/r” and “/t” switch.
Above two commands have been scripted in Windows command shell batch script that easily perform the task of taking ownership and grant full control permissions to Administrators user group by typing simple command. Alternatively, users can add “Take Control Of” option to right click menu so that the next time you need to take control of a file with full control permissions, it’s just a one click task.
Feb 04, 2010 | Acer Aspire™ T180 PC Desktop
I have windows vista and can't delete mp4 files from my comouter
Even i had the same problem and i could solve it.
Try this
1) Open a Command Prompt window and leave it open.
2) Then, Close all open programs.
3) Click Start, Run and enter TASKMGR.EXE
4) Go to the Processes tab and End Process on Explorer.exe.
5) Leave Task Manager open.
6) Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.
7) At the command prompt type DEL where is the file you wish to delete.
8) Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.
9) Close Task Manager.
Oct 31, 2009 | Nextar MA933A MP3 Player
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Sep 17, 2009 | Microsoft Windows XP Professional With...
Counterfeit alert on desk top
wga-notification1.jpg If you get this picture, then try the following to diable this service:
First,
  • Lauch Windows Task Manager.
  • End wgatray.exe process in Task Manager.
  • Restart Windows XP in Safe Mode.
  • Delete WgaTray.exe from c:WindowsSystem32.
  • Delete WgaTray.exe from c:WindowsSystem32dllcache.
  • Lauch RegEdit.
  • Go to the following location:
    HKEY_LOCAL_MACHINESOFTWAREMicrosoft
    Windows NTCurrentVersionWinlogonNotify
  • Delete the folder ‘WgaLogon’ and all its contents
  • Restart Windows XP.
Or,
disabe and rename the files ‘WgaLogon.dll’ and ‘WgaTray.exe’ in C:WINDOWSsystem32 folder by using the program Unlocker seems to get rid of all the nags/popups.
you can download Unlocker here:
http://ccollomb.free.fr/unlocker/
Or,
change and disable the execute bit of WgaLogon.dll:
  • Turn off Simple File Sharing in Tools -> Folder Options -> View tab.
  • Right click WgaLogon.dll in Windows Explorer and open the Security Tab.
  • Click Advanced button.
  • Uncheck the Inherit box at the bottom.
  • Click the Copy button.
  • Click OK.
  • Go through each listed user/group and remove the “Read & Execute” permission for WgaLogon.dll, leaving the “Read” permission as-is.
  • Click OK to apply the permission changes.
  • Close the file properties dialog.
  • Restart the computer.
  • Turn “Use simple file sharing” on (optional).
OR
Install ZoneAlarm firewall, and configure to kill or disallow “WGA” in the allowed programs section.
Or,
Download and install Autoruns from www.sysinternals.com. Run the program, go to the WinLogon tab and uncheck (disable) the WgaLogon, as suggested by PSnet.
Hope this helps, and please rate! ^_^
Jun 19, 2009 | Microsoft Windows XP Home Edition
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
Desktop and Task bar disappearing
You computer is infected by the spyware virus try to run in the safemode and download and install spyware doctor of pctools also the registry mechanic this two utilities is very helpful in term of spyware virus. But sometime if your computer infected by the UST.AVI virus you cannot install any program even the anti virus. The virus automatically close any program you install to prevent the anti virus to install in the system. If this happen the only way to salvage the files is reinstall the windows in the other directory then after you finished install windows. You can copy now the the files in the old directory copy of the windows your needed files. and delete the old windows directory permanently.
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Dos Problem
If you are only trying to move your data file, then create the new directory using the cd command e.g.  cd test.  Then move the file to the new directory either using the move command or the copy command eg. copy test.file c:\test\test.file
Alternatively you should try using the old text editor program in dos to load your file and then save to the directory of  your choice.   good luck
shane67
Mar 03, 2008 | Computers & Internet
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
