Question about Amana AGDS902 Gas Kitchen Range
Amana first addition oven (approx 10 years old) will not heat
The oven will come on but will not hold temperature to bake consistently. On the side of the oven is what I believe is a thermocoupling. I have successfully used a scratch pad to remove any coating or residue which has temporarily solved the problem. Also, when the oven comes on, it is slow to come on and to heat up. Could you please tell me what this part is and if replacing it will solve my problem
I had a similar problem with my Amana oven, also about 12 years old. It was slow to heat and sometimes wouldn't reach the set oven temp. I replaced the oven igniter on a tip that it wasn't drawing enough current to open the gas valve solenoid. That did the trick. It starts immediately and heats to the right temp. Good luck. Joe
Posted on Jan 14, 2009
Where is the thermostat on range WFE540H0AW located?
The oven should still be under warranty so you should be on the retailers case where you purchased it as they are liable for warranty claims. The simmerstat which you call the thermostat is the part that the temperature knob is attached to. They pack up fairly regularly and aren't expensive or hard to replace but definitely should last more than a year and be replaced under warranty. Give the shop where you bought it hell!
Aug 22, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Latch signal mismatch error
first ,check the simple .... reset both dials to off position, then reset the time bake and clock on the upper left hand side ,make sure the start stop clocks are reset , turn back on broil ,bake temperature and see if this fixed the problem,...
Aug 05, 2012 | Kenmore Kitchen Ranges
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be...
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
Element Question
In most ovens, both elements are used during the warmup phase even when used for baking and after the set-temperature is reached, the lower element keeps it stable.
You should be able to detect which one is not working with your bare hand. Set the baking temperature for 250-300 degrees, leaving the oven door open. Hold your hand at different heights in the oven and you should be able to sense which element is working and which isn't within a couple of minutes.
If you still aren't certain, then try using the broil element only. If it is heating, then it's obviously OK and that would point to the bake (lower) element by default.
A final check could be done with an open door and hovering with your hand over the lower element; no heat = defective.
Mar 03, 2009 | Amana AOES3030SS Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Oven heats unevenly and does not hold temperature
Can you replace the elements?
May 12, 2017 | Ovens
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Amana AGDS902 Gas Kitchen Range Logo
572 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
