When I'm walking on my treadmill the belt is stuttering because the roller bar is pushing up against the part that houses the motor. If I'm not walking on it it works fine. What can I do to keep the roller from pushing forward?
1) LUBE the deck belt, this happen to due the lack of maintenance according with your instru.manual follow the step donwloa your instruction manual. go www.fitness.manualsonline.com or www.iconservice.com
2) LUBE the rollers bearing very well.
3) Tight with NOT much tension the drive belt.
4) Adjust the tension deck belt see the diagrams attached.
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
SOURCE: Treadmill motor not coming on, belt not moving
most likely cause is a burnt out motor controller, you'll need to replace it.
SOURCE: the motor belt slips on my treadmill and does not
Remove the cover, you will see the motor and an adjusting pivot bracket. Loosen the nut/screw on this bracket, use a HD screwdriver or pry bar and move to take the slack out of the belt. The resistance/tension in belt should be 3/4"-1"
SOURCE: belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Drive Belt Installation for Treadmills
The drive belt is used by the motor to drive the
treadmill walking belt via the front roller pulley. A drive pulley is mounted
on the roller and the roller has knurling or a sleeve to help it drive the
walking belt. The treadmill console detects the current speed of the treadmill
by monitoring the movement of a magnet mounted on the front roller pulley with
a reed switch or by using an optic switch which monitors an optic disk mounted
either on the front roller or on the motor shaft. If the sleeve moves to the side, you will not
be able to keep the belt centered and many optic disks can be warped if pushed
to the side by the sleeve if it moves, but we do have replacement sleeve kits
if needed.
Steps to Replace
Drive Belt-
1) Remove the safety key and unplug the treadmill
from the wall outlet.
2) Remove the screws securing the motor hood and
gently remove the motor hood.
3) Using an Allen wrench provided with the
treadmill, loosen the two rear roller adjustment bolts until the rear roller
comes into contact with the walking board.
Turn the bolts and equal number of turns on each side and keep a count
of how many turns you made so you will know how to properly re-tension the
walking belt.
4) Remove the drive belt from the motor pulley.
Place a screwdriver between the pulley and the belt and turn the pulley by
hand. Use the screwdriver to guide the belt over the edge of the pulley. Be careful with the screwdriver to prevent
damage to the pulley.
6) Mark the position of the front roller axle on the
front roller bracket above the front roller adjustment bolt using a Sharpie
marker so you will know where to put the bolt back into position. Remove the
front roller adjustment bolt if your treadmill's front roller has a pitch adjustment
bolt. If your treadmill does not have
exposed roller bolts you will need additional instructions. Please see the troubleshooting section on our
website for further help.
7) Gently slide the front roller from out of its
mounting position on the frame. Do NOT
remove the roller from the walking belt.
8) Slip the old drive belt off the roller and loop
the new drive belt onto the front roller pulley.
9) Replace the roller back into its slot on the
pulley side and re-tension the front roller pitch bolt to its proper place
using the Sharpie mark as a guide.
10) Using the screwdriver, loop the drive belt over
the motor pulley. Many Icon units
originally had the drive belt misaligned by design (if you can believe
it). This was to use the side load of the
drive belt in order to keep tension lower.
It does lower amp draw for the machine and replacing a side load drive
belt occasionally is much cheaper than replacing a motor and/or controller so
if your original drive belt was off-centered, install the new belt in the same
manner.
11) Re-tension the walking belt.
12) Plug in the machine and check the drive belt for
slipping. You can use some automotive
fan belt dressing on the grooved or contact side of the belt to help it with
grip on the pulleys and it will treat the belt as well. We prefer using belt dressing rather than
over-tensioning the belt for the aforementioned amp reasons as well as
additional stress placed on the drive system parts.
13) Replace the motor cover and test.
14)
Make sure the walking belt is not slipping and is properly aligned and your
treadmill is ready to use.
Copyright 2009 by TreadmillDoctor.com, Inc.
All illustrations, photographs, and scanned images, and text are the property of TreadmillDoctor.com, Inc. and may not be reused, retransmitted, copied, given, sold, or bartered to any third party. The recipient of this property is authorized to use it only in the manner expressly indicated by a staff member of TreadmillDoctor.com, Inc. All rights reserved.
1) Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. 2) Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, . If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps If a second attempt does not repair the problem 3) If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Please check this video: http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related E.CUADRA MANAGUA, NICARAGUA. C.A
