Question about Radio Shack Cinego D-1000 Multimedia Projector
Replaced lamp unable to reset lamp life message.
Replaced lamp, unable to reset lamp life counter through Management Menu. I can access the menu but it will not allow me to togle down. Suggested lamp replacement message still shows up. Contacted ph# in owners manual, just refers me to Radio Shack and they cannot help. Any other methods to solve problem?
Mechanic688
  • 204 Answers
SOURCE: Radio Shack Pro-2043 scanner
Hi, According to this site, the manual is not available. But this link has all the info available on separate pages to be printed off. All you have to do is copy and paste and print,, can't get too much easier.
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=20-415&
Name=Radio%20Scanners&Reuse=N
I hope this helps you out,, Mechanic
Posted on Jan 24, 2008
oldnovii
  • 667 Answers
SOURCE: Owner's/Instruction Manual
Hi SDGirl - This is a slightly older model and there's not much out there. You won't find one at Tandy or Radio Shack Sites. I'll give you a link where you can find it ( sort of) in sections. I believe it will tell you everything you need to know. If I were you I'd probably copy and paste each section into Word or something so you'll have it all in one place. This is about the best out there. If this solves your problem PLEASE rate this as fixed. ( I looked alot for you). If you need more help just add a comment and I'll be happy to assist you further. If this doesn't solve your problem let me know before you rate and I'll try for something better. Thanks.
http://support.radioshack.com/support_electronics/36547.htm
Jeff
Posted on Jun 11, 2008
PyroPCMan
  • 405 Answers
SOURCE: Radio Shack 17-6020 Paging system
Good Day,
See this link for all available documentation:
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=17-6020&Name=Pagers&Reuse=N
Hope this helps
Posted on Jul 09, 2008
thedayos
  • 57 Answers
SOURCE: Need a instruction manual
Click the following link...
http://support.radioshack.com/support_phones/doc69/69751.pdf
There's your answer!
Don't forget to click "FixYa" below!
Thanks
Len
Posted on Mar 26, 2009
  • 53 Answers
SOURCE: Need a Owner's Manual for Radio Shack TAD-3822 (Cat. #433822)
here is a link to the page where you can get your owners manual
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-3822&Name=Search%20Results&Reuse=N
Posted on Aug 31, 2009
On screen message "lamp life over, error!!, which
Hello John:
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter...otherwise you may get an annoying reminder every few days if you're surpassed the predetermined hour mark.
To Reset:
Ensure the TV is powered on.
1) Press and HOLD the MENU button on the TV
2) Press and HOLD the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
3) Let go of the REMOTE button first, then release the button on the TV
4) Press and HOLD the ENTER (or OK) button on the TV
5) Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
6) Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly...
Mar 22, 2011 | LG Televison & Video
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
Replaced lamp. timer won't turn off
I think the timer light is blinking to indicate the lamp usage is near end of life, it doesn't actually know if lamp is bad it is just a counter. I beleive if you go into the tv menu and look for timers you will see one for the lamp. You can reset it and the counter will be reset to 0 and blinking should stop.
Sep 11, 2010 | Mitsubishi Televison & Video
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
Need to reset the Lamp counter.in my Samsung HLR5667W
here you go here is this web site where you can see how to reset your lamp
Jan 15, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Reset the drum counter on Brother MFC-9840CDW
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Jun 27, 2009 | Brother MFC-9840CDW Laser Printer
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
47 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
