Question about Indesit W 123 Front Load Washer
Zanussi ZKC5540W ceramic hob keeps turning itself down
When you turn the hobs up to 6 after a few minutes you hear a faint click and the hob has turned itself down on to a very low heat.
Do you think it is an element, and can they easily be replaced?
  • Indesit Master
  • 3,463 Answers
More likely to be a faulty regulator switch, if the element was faulty, it is unlikely it would work at all.
Plz rate my solution. Thanks.
Posted on Dec 23, 2008
How does my hob cut out after it has been on for a while then when it cools down I can put it on again
It's possible that there's a connection which is affected by the heat, or there's a faulty thermal cutout.
Search online under "zanussi model***** faults" and see what turns up. Also contact zanussi helpdesk online.
Jun 29, 2015 | Zanussi ZEV6940FBA Black 590 mm Electric...
Why does my Zanussi hob turn itself off then when it is cold I can put it on again
forgive me but being an American what is a hob thinking it is not a washing machine .
Jun 29, 2015 | Zanussi Washing Machines
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
CERAMIC HOB EC 60 T. LETTER L NEXT TO CONTROL BUTTONS
Hi i had the same problem the L means Locked after lots of combinations of button pressing it is the - button in the middle and the 4th RING front right togeather that will unlock it took a couple of goes so persevere
Apr 15, 2009 | Kitchen Ranges
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Indesit W 123 Front Load Washer Logo
394 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
