Question about Uniden Cordless Phone
Handset wont register
GE model#25825ge3-A Handset displays reads"Handset needs registration" The registration instructions say to push base page and when handset beeps press select. however handset will not beep. Any ideas? Thanks
  • Anonymous Mar 28, 2008
    my cordless GE phone says handset needs registration. Tried beeper and phone doe not beep
  • Anonymous May 12, 2008
    Cordless phone is totally dead. I have tried to press program but nothing happens. It has been registered before but it won't register now.
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Posted on Apr 30, 2009
Try putting the second handset on the base charger.
Posted on Apr 24, 2008
It took a long time and it is the base unit that eventually beeps. It seems to take longer for each handset you do. The instructions were the same for the 5.8 gHz units.
Posted on Aug 25, 2007
Unplug the battery and try again. Worked for me.
Posted on Jun 17, 2007
3 Suggested Answers
SOURCE:
SOURCE: registration
HI TEAM ,
PLZ SEARCH MY COMPUTER SCANING PROBLEM INSIDE.
REGARDS
A. S ENTERPRISES.
KANPUR
Posted on Nov 13, 2007
  • 3 Answers
SOURCE: tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
Have a replacement handset, base is cs6729-2 handset is cs6729-3 how do i set up new handset to see base?
This sounds like a registration problem, the new
handset must be de-registered from its original
base and then registered to your base.
NOTE: the CS6729 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Oct 29, 2015 | Vtech Lands Phones
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
I have a GE model 2810GE AND THE screen say's HAND SET NEEDS REGESTRATION. WHAT SHOULD I DO ? CHARLES
This is from the instructions at GE's site for the model 28110 (you said 2810, which isn't found):
  1. Press the mute/program button. Hold BASE PAGE for 5 seconds, then PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.)
  2. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number
Hope this helps. Thanks for using Fixya!
Feb 11, 2010 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
GE 5.8 GHz Model No: 25825GE3-A
Try this.. press the prog/mute button. It will ask you to press the page button on the base Press the page button and the handset will say it has to have a name - press the prog.mute button and it will name the handset - not sure if you need to press it 2x for the 2nd handset you have
Nov 08, 2007 | Uniden Cordless Phone
Cordless GE phone issue. 25825GE3-A
1. press the "talk" button FIRST
2. then press "program" button and follow instructions on screen
only one phone said "needs registration" but had to register all 4 phones but this worked for me
hope this helps
Sep 11, 2007 | Uniden Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Uniden Cordless Phone Logo
940 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
