Question about Dell Inspiron 6000 Notebook
On boot up screen reads "Loading PBR 2...done"
The system stays stuck on this message. I have run a complete diagnostic on all sub-systems related to the booting of the unit. All tests passed.I have the same problem.  out of the blue my system won't boot up, and displays loading pbr 2 ...done    A disk read error occurred.
2 questions: what do i do to fix it, lots of activity on this Dell issue on Google, i am obviously not alone.
question 2, why doesn't f%$#ing Dell have any firm answers on this?  Their site is useless on this issue, despite the fact that it seems to be a common problem.
thanks cliff
  • Dell Master
  • 13,433 Answers
Try repairing your windows installation with the windows setup cd. report back how it goes.
Insert the cd into the drive, start from cd when asked, follow the on screen instructions to install windows, when asked you can repair the windows installation, not repair console, repair console will come first, the repair install comes later in the setup.
Posted on Dec 23, 2008
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
I have a inspiron i1011-26600bk and its telling me a message that says Loading PBR for descriptor 2...done. What should I do?
"Loading PBR for descriptor 2 ... failed" would be the exact error message if the MBR is unable to load the partition boot record for the second partition. There may be more, but here are three possible causes:
1) the partition table is corrupted so that the descriptor points to the wrong place (i.e., says the partition is one place when it's really somewhere else);
2) the partition table descriptor points to the right place, but the boot record there is corrupted or has been erased;
3) The hard disk is failing and having trouble reading the sector with the boot record.
To check (1), visit www.goodells.net/dellrestore/fixes.htm and download the dsrfix utility. In short, if dsrfix reports a clean bill of health, then (1) isn't the problem.
To check (3), run hard disk diagnostic tests. Press F12 when the machine is starting and see if the bios boot menu offers you a hard disk diagnostic test that you can run. Or even better, if you know the brand of the hard disk, most manufacturers should have a free diagnostic utility you can download to test the hard disk.
If it's not (1) or (3), then use Ctrl+F11 to run the Dell restore utility to recreate the Windows partition.
Mar 12, 2011 | Computers & Internet
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Loading pbr 2 done message
battery had all lights lit. Took it out and now the front battery display light is flashing. I have a new mother board could there be a problem with recognition?
Mar 13, 2010 | Dell Inspiron 6000 Notebook
Start up gets to "Loading PBR for descriptor 2... done"
I suspect that the viruses had infected some of the files that windows needed to boot up. The moment you ran the Mcafee, the scanning might have deleted or quarantined those files. That is the reason you're having this Loading PBR message because it is now trying to boot from the network and not from the hard drive. You will need to repair windows using the CDs that came with the computer (the Operating system CD/DVD) and run CHKDSK /R at the screen where it says 'repair your computer using the command prompt". If this does not work, chances are, you may need to reinstall windows and everything and that all information in your hard drive will be wiped out.
Jan 03, 2010 | Computers & Internet
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
Dec 15, 2008 | Dell Inspiron 6000 Notebook
When i turn my dell inspiron 3000 on after about 5 seconds of loading this screen comes up and say loading PRB 2 ....done and just sits like that for ever and does nuthing can u help me ?
Loading PBR are caused by file corruptions on system partition. You can use a bootable cd (like ntfs4dos) and try to run chkdsk. You can also restore your dell to its original software, but that would cause you to loose all your dat. Try using a live linux cd (like opensuse of ubuntu) to boot your pc, recover / backup your files maybe to an external had disk, then perform any repair that you want, just to be safe.
Aug 21, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
85 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
