Question about Westinghouse LCM-19v1 Monitor
Will not display output from Computer
Shows error. "out of range"
  • 36 Answers
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Posted on Dec 26, 2008
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
Trying to connect dell desktop to my Samsung DLP HL-R5064W tv through vga cable to watch movies. Toggle source button on remote to pc, but receive an out of range message. please help
"Out of range" message indicates that the output from your computer to display it from your Samsung HLR5064W DLP TV is too large. You need to adjust the screen resolution settings for you TV. I have attached images of display settings dialog boxes from different versions of Windows.
You may open the display settings of your computer by clicking on START > CONTROL PANEL > DISPLAY. While your TV is connected, click on IDENTIFY button. You will notice that numbers 1 and 2 will appear briefly on your screens consecutively. As the dialog box shows 2 monitors with numbers 1 and 2, click on the monitor with "2" on it. Then, adjust resolution to 1280 x 720 as this is the highest resolution your TV can handle. You may adjust the TV (monitor #2) to be IDENTICAL or to EXTEND the display of your computer. You can also assign it as the main monitor but not recommended. Click OK then try to toggle your computer's display. You should be able to see a display from your TV this time.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Samsung HLR5064W DLP Projection TV
Hey, was wondering what the message center display symbols and what they mean, lost my manual
There are five trip computer displays which may be stepped through by pushing the MODE button. The information will appear in the following order:
D AVG ECON (Average Fuel Economy): This shows the average fuel economy since the last reset.
D INST ECON (Instantaneous Fuel Economy): This shows fuel economy for the most recent second of driving.
D RANGE (Trip Range): This shows the estimated distance that can be traveled with the remaining fuel. The fuel economy used to calculate range is based on the last few hours of driving. When in a low fuel condition, LO is displayed.
D FUEL USED (Trip Fuel Used): This shows the accumulated fuel used since the last reset.
D AVG SPEED (Average Speed): This shows the average speed since the last reset.
You can download a replacement Owner's Manual here: 2002 Chevrolet Impala Owner's Manual (PDF file from www.gmownercenter.com)
Oct 05, 2010 | 2002 Chevrolet Impala
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
Output bin is full error on hp laserjet 2055
check the flag that hangs down as the paper is exiting printer.... sometimes the flag gets stuck in the up position..(causing the printer to think there's a big stack of paper needed to be taken off the machine
Feb 05, 2010 | Minolta QMS PagePro 9100 Laser Printer
"S A6" Error shows in the display
unaBLE to check/locate yor model number inthe maytag library, but you can check your manual( if you have it) or call the manufacture for a replacement of it. your unit is set in "sabbath" mode. "SAB" the book will explain how to get it out.
Mar 23, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
WP Touchpad does not work.
The error code of F2 and E1 on your gas range is indicating a keypad failure or an Electronic Range Control (ERC) board failure. The ribbon connector on the keypad could be damaged or shorted. One of the buttons could be stuck or shorted on the keypad. There is a good possibility of a failed (ERC) board as well.
I recommend having a service technician come out and diagnose which part failed and repair your range.
Dec 18, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Our 6 year old Kenmore glass top range was scheduled to do a cleaning last night. This AM it is not hot, but is stuck on lock and shows error codes E1 F5. We shut off the power and then on again. It...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 02, 2008 | Kenmore 95822 / 95824 / 95829 Electric...
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Westinghouse LCM-19v1 Monitor Logo
115 people viewed this question
Top Westinghouse Computers & Internet Experts
Steve Allison
Steve Allison
Jim Goldsmith
Jim Goldsmith
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
