Question about Kyocera KM-1505 Copier
CANON MODEL IR 2016 J
Is not functioning well. Error message comes as follows "
"Drum is not set please insert drum"
Service technician also checked and removed/installed new drum. Again the same error is showing. We await your technical advise if possible
  • Ahmad Hussain
    Ahmad Hussain May 11, 2010
    Kindly conform the brand and modle.
    Novelist:
  • 126 Answers
There are connection ( look like silver pads on most) make sure that they are clean and not bent. If bent, GENTLY shape to make contact. Also check connect to pads, should be 2-4 wire connection --- seed properly.
Posted on Jan 05, 2009
  • jpd8 Jan 05, 2009
    Also check side cover door ( front cover) switch. Make sure door ( cover) closes properly.
Canon iR2022, now: "drum is
check the drum insert flag in the drum unit(front side).it has to be intact as it has to match the sensor when the drum unit is inserted. u can see it when u insert the drum unit it is it at the front of he machine.u can also bypass it by placing a paper int the sensor
Jul 21, 2011 | Canon iR 2016i Black and White Copier
I have message error for canon copier IR2016 "System Error E019" Please help me on how to fix
E019 usually means the waste toner is full. The waste toner is, I believe, in the drum, so you'll need a new drum. The drum appears to be under the front cover. You might want to call your service rep. if you are not comfortable doing this yourself.
Mar 20, 2011 | Canon imageRUNNER 2016 All-In-One Laser...
E019 in canon copier 2016 j.the machine runs n at last error comes E019, may be toner censer has problem how can i solve this.where would be the censer pls help me .
You need to replace the drum unit. The E019 error code means that the Waste Toner is full, but the problem with this model is that the waste toner cartidge is built in the drum unit so you have to replace the whole drum unit.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Showing system error code E019
Waste toner bottle is full. Needs to be replaced or emptied. I believe it is the drum cart. that will need replacing to correct the error. It is an all in one unit. Unless you are a tech and can take it apart it will need to be replaced, if it is under maintanence it should be covered.
Hope that helps,
TankMurdock
Apr 24, 2009 | Canon imageRUNNER 2000 Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Kyocera KM-1505 Copier Logo
98 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
