Sony KP-51WS500 51 in. Rear Projection Television
Problem for Sony KP-51WS500 51 in. Rear Projection Television
Faint red lines in a curved arch like pattern
By Stew on Apr 10, 2007
I have a 4 year old 51in Sony projection HDTV,when the picture is dark you can see faint red lines in a curved arch like pattern across the screen. The screen also has a red hue to it. Any ideas? Thanks
Same Problem
Sep 25, 2008
-   Same problem arched red lines picture has very bad red tint and occasionally tv will suddenly turn itself off.-   towin12
Sep 09, 2008
-   same problem only green lines appear on screen-   Guest
Jul 28, 2008
-   I bought the TV 5 years ago and two months after I purchased it I had problems with it where they replaced the board and some of the lamps, a few months back I ran into the same problem and after they fixed it again, of course I only was reimbursed $94, I noticed that I had another problem with a faint blue line in a curved arch like pattern. I have spoken to Sony and am waiting for resolution.-   Guest
Jun 22, 2008
-   the screen turns red.-   Guest
Jun 18, 2008
-   having the same probelm as all of you,but mine also has no signal at the bottom left hand corner. With the red line in the middle of the screen. That gets bright and then dims down ot a lite red line. -   drlee1025
Best Solution
posted on Sep 10, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Solution #2
posted on Mar 08, 2008
Very Helpful)
GtownK
Rank: Apprentice
Rating: 99%, 8 votes
I got a similar problem with red lines on my Sony. I want to try this solution. Does anyone know how to take the front cover off in order to get to the CRTs?
Thanks
Paul
Was this helpful?
Yes
No
Solution #3
posted on Mar 31, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
To access the focus block with the screen controls, remove the 2 plugs under the speaker grille. There is a philips head screw under each plug. Remove both screws. the speaker grill is now free. Pull the bottom forward and the grille will come off. The top is just held by tabs behind the screen bezel. Be careful as there is wiring to the grille for video input 2 and the front panel controls. There is a piece of fiberboard held on by 4 screws in the center which was formerly covered by the grille. Remove the screws and the panel and the focus block is right there. Each color is labeled for both screen level and focus. Adjust the screen control of the color producing the lines until the lines just disappear.
Solution #4
posted on Apr 18, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
OMG! Thank you so much!
I finally managed to fix the curved red lines on my Sony.
I took the front of the TV off, removed the plywood cover, and turned down the power adjustment on the red (lower right hand knob). voula! no red lines!
Solution #5
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same probelm, the Sony tech huy adjusted the red Screen Voltage on the screen/focus block in the front of the tv.
Just aslight turn of the screw and now it's all better... I paid $50.
He said that occasionally it needs to be done, and that that eventually I'll have to do blue and green as well.
Hope this helps, Good Luck
Clark
Solution #6
posted on Jun 24, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Great solution on adjusting the lines here:
http://www.somelifeblog.com/2007/06/sony...
Solution #7
posted on Jun 04, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the faint red and blue lines and a blue tint to the screen. Did the screen voltage adjustment for blue and red guns, worked like a charm. Took about 10 minutes and didnt cost me a penny!
Thanks a lot!
Solution #8
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the problem, I fixed as described above but it lasted less then a month and then the red and blue tube started at it again, with large lines on the screen. The power/standby would blink for 5 times again and again.
I called service magic from an ad I found on this site and they sent a guy to fix it. He seemed familiar with the problem. He tapped the tubes, both the red and blue and each time he tapped, the screen would bleep. He said by tapping the tubes it cleared up some loose material in the tube and that this normally fixed the problem, but not for sure, sometimes it works, sometimes it not.
now $134 later the picture is looking great
Hope this helps
JR
Solution #9
Helpful)
trishet
Rank: Apprentice
Rating: 93%, 3 votes
I have the same problem with my Sony projection TV, it has blue horizontal lines although mine over 4 years old, maybe even 5.
I'll try your suggestions, thank You so much!
Was this helpful?
Yes
No
Solution #10
posted on Jun 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have had the same problem, the CRTs are failing and will need to be replaced in 6-8 weeks. The CRT's are no longer in production and have to be located after market or rebuilt. Wrote SONY Electronics President regarding the quality on this model but received no reply. This was the last model of the rear projection type television they produced prior to DLP. Mine had aways been a lemon, great picture, too many shop calls. Get an extended warranty if possible. I'll replace mine with a LCD this year, not a SONY because of the expierence with this and Pres. non-reply.
Popular Solutions for Sony KP-51WS500 51 in. Rear
Questions and Unsolved Problems for Sony KP-51WS500 51 in. Rear
Do you recommend Sony KP-51WS500 51 in. Rear Projection Television?
Answer
Answer
colors have separated pink and green shadows picture blurry is it worth fixing?
Answer
Standby light is on all the time and thus there is no picture
Answer
TV goes on and then goes off and red light blinks
Answer
how do i tell if the tubes are goin bad in my sony rear projection tv
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 18, 2008
you can see all the colors in 3d in an arc
Comment by Guest, posted on Mar 17, 2008
red lines arched and kida bold on the tv.
Comment by GtownK, posted on Mar 09, 2008
I had the same problem with my Sony KP-57WS500, but I fixed the problem using the posted solution. Saved some money. Thanks to all.
Paul
Comment by Guest, posted on Feb 16, 2008
yes i have the same problem the red crt is out and it coist 187.40 from sony and that is the only color that they have i took it to a reapir center they wanted 350 a color there is one for blue, one for green and the repair guy said they are also going out at the cost of 350 what a joke the tv is only 5 years old
Comment by dans7282, posted on Feb 14, 2008
I have the exact problem with my Sony. Red arced lines in the dark areas. Please help I can,t find the Red adjust.
Dan
Comment by 26557, posted on Jan 25, 2008
I have the same problem with the red arching lines. I have a 4 year old Sony KP-46WT500. Does anyone know where I can find the adjustment screws on this model TV?
Comment by Guest, posted on Dec 23, 2007
We have the same model Sony and have had lines on it for about a year or so. I thought maybe it was the connection. I am glad I finally looked it up on the internet and my husband and I fixed it in 10 minutes. Our line were mainly blue and red and in a curved fashion. My husband didn't even have to do an 1/8th of a turn to fix it. Just touching the screwdriver to the red, and blue knobs fixed it up. Wish We would have done it sooner.. hopefully it lasts!!!
Thanks!!
Comment by Guest, posted on Dec 16, 2007
same issues
Comment by spiggz, posted on Dec 13, 2007
I have a kp51ws500 sony tv. The tv id showing the picture with shadows and the displays are doubled such as two 2's for channel 2 etc
Double images. Any help would be appreciated
Thanks.
pj
Comment by Guest, posted on Dec 03, 2007
I have the same issue how do I fix but mine has red and green lines
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-51WS500 51 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
