Question about Dell 926 All-In-One InkJet Printer
Dell 926 printer wont print text. - Dell 926 All-In-One InkJet Printer
  • Cheryl May 11, 2010
    Open Notepad and type a few letters like "test," then try to print to your Dell 926. What happens? Is there an error message? What does it say?
    ~~Cheryl
    Sniper:
  • 51 Answers
Do you receive and error msg like printer communication not available?
if you're receiving printer communication not available, you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
have a great day
Posted on Oct 01, 2009
Vivektj
  • 55 Answers
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Posted on Mar 02, 2009
  • 508 Answers
SOURCE: i keep getting the " covers open " on my dell 926 printer. help
sensor or switch not working or sensing find and figure out why not working maybe dirty blow out with compressed air!!!!! :)
Posted on Jul 06, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
Rossiman46
  • 50 Answers
SOURCE: How to install ink into printer 926 dell
There should be a button on your printer, you would need to press it in untill the carriage moves over into the install new cartridge position, you will know when it happens you should hear it.
Take out old cartridge 7 install a new one, normaly when you shut the lid down the printer will automaticaly do a head clean better known as priming the cartridge, you should then be ready to print.
Posted on Nov 06, 2009
Testimonial: "Didn't find any button to push"
pineworks
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
Printing only left side of a page, right side totally blank
What application are you using to print text? Word?
Try a simple application, like Notepad or Wordpad, to print some simple two-liner text.
Does printer print ALL the text on left side or just the half of printable material?
Even if you are indicating that page size is correct, looks to me some problem with the selection of print area.
Oct 03, 2015 | Dell 926 All-In-One InkJet Printer
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
My dell aio 926 wont print it makes the sounds but paper is blank i uninstalled and reinstalled and cleaned cartridges with cloth says there ink for 43 papges help me
Maybe it has not ink for the color you want to print or the printhead is clogged. In this last, you should change the printhead.
Thanks.
Dec 11, 2010 | Dell 926 All-In-One InkJet Printer
My Dell photo 926 prints blue lines on my pages
your color printer cartridges needs to be clean, removed this and wipe with a dry cloth and reinstall again this could cause some streak while printing
hope this helps
Jul 28, 2009 | Dell 926 All-In-One InkJet Printer
I keep getting the " covers open " on my dell 926 printer. help
Jul 06, 2009 | Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Dell printing problems
Try fanning the paper and see if that works.
Jun 30, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
332 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
