Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Weird problem not convergence
I have this JVC TV and have a problem... for the last couple of months when I switched from any input (i.e. video 1 through digital in) to another input the screen would display either one of three things: 1.A plain grey screen with the bottom of the screen having a bowed black section. 2. A plain green screen with the bottom of the screen having a bowed black section. 3. A really weird vertical scramble sometimes many colors, other times only black blue and green. 4. A screen split vertically in half with one side blank or grey, and the other side scrambled vertically. 5. Plain blue screen. 6. Semi scrambled image in black and white, but looks more like a photo negative. I have equipment hooked up as follows: Digital In - DirecTv HD H20 receiver DVI cable Video 1 - DirecTv HD H20 receiver through component cables.(as a back up) Video 2 - Playstation 2 with component video Video 3 - Sony DVD with S-Video On screen menus work fine Now, the tv won't even display a picture except for one of the above things. It used to fix itself by cycling the power but now it just doesn't work. Any help appreciated
Mine is doing the exact same thing! have you found a fix yet?
Posted on Jun 09, 2007
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
I have a model av48p776 jvc I am getting jitter lines across the screen more often than not and the bright comes and goes what do I need to do to fix it I would hate to get rid of the TV I just bought it
JVC AV48P776 Jitter and Brightness Varies
Check for convergence failure. Convergence Gallery Try adjusting convergence in user menu. If convergence display is messed up or adjustments do not work correctly, you have an Intermittent short circuit within an STK IC.
Look at menu screen with an unused input (antenna or video). If menu is stable and clear, TV may be OK and you may have a signal input problem.
If it is not poor quality input signal or convergence problem, someone has to troubleshoot to determine if it is a Video, Processing, Power supply or CRT related problem.
Most likely convergence.
easyab
Feb 28, 2010 | JVC AV48P777 Television
The remote just magically stopped working, even after new battery
Have you tried pressing the 'input' button again this time to switch from video to tv? This happens in quite a few cases where 1 remote is used for many products. Please try and let me know.
Aug 21, 2009 | Televison & Video
Cannot get 27" jvc av-27530 tv to recognize playstation 2
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
Jan 04, 2009 | JVC AV-27530 27" TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Unable to switch to Aux in order to play xbox 360
http://books.jvcservice.com/Download/566962143/LCT1467-001A-A.pdf
at JVC Support Page , download owners manual , listed above , on page 35 , it appears you should press INPUT button and cycle thru TV / video 1 / video 2 / V2 component / and video .
depending what video input option you used to hook up your Xbox to , you should be able to figure it out from here.
Dec 26, 2008 | JVC TM-2703SU 27" TV
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Mistubishi Convergence/video display problem
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 26, 2008 | RCA P56923BL 56" Rear Projection...
JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
May 13, 2008 | JVC AV-48WP30 48" Rear Projection...
Audio input/output
It sounds very much like your receiver needs repair by Sony.
www.esupport.sony.com
Sep 06, 2007 | Sony STR-DE998 7.1 Channels Receiver
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
289 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
