Question about ASUS Eee 4G Notebook
WLAN cannot detect any wireless connections
How come my wireless connection work now since I start to enter an IP random number.How could I retrieve my connection?thank you
  • 2 more comments
  • almdbl Jan 05, 2009
    I have same problem with my toshiba satilite L40
  • oliva01
    oliva01 May 11, 2010
    Here is some great source to solve any kinds of laptop's problem.
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Here is some another Great source to download any kinds of laptop Drivers.
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download arga-20
  • Default KITT
    Default KITT May 11, 2010
    mostly used is "255.255.255.000", "255.255.255.0", "0.0.0.0", "000.000.000.000", or "127.1.0.0". Be sure to use one of these.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Could you give me a few more details please? Normally home networks are assigned IP addresses randomly from the Wireless Access Device...
  • 74 Answers
Hi
Go to setting>network>LAN> then configure ip and all
harry
Posted on Aug 08, 2009
I can't access wifi networks the wireless internet connection got deleted so how can u help me
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Jan 20, 2013 | Computers & Internet
L305-s5914 wireless problem
Jan 16, 2013 | Toshiba Satellite L305D-S5914 Notebook
I wold like to use wireless my laptop
Jan 16, 2013 | HP Pavilion Computers & Internet
How to start for wireless
Jan 16, 2013 | Toshiba Satellite L645d-s4056
Wireless internet connection
Dec 11, 2012 | HP Black p2-1343wb Desktop PC Bundle with...
Having problems connect my child DSXL to the Internet please advise
This will get you a wireless connection to the internet if you have the approprite internet wireless modem.
if still no joy
Hope this helps.
Nov 27, 2012 | Computers & Internet
How do I change the IP address on my laptop?
Simply you can change it by follow the steps below..
Do this:
go to start > run type "cmd" hit enter
in the black box type "ipconfig/all"
record all information
get out of that
go to Control Panel > (classic view) Network Connections > go to your connection and right-click, Properties, TCP/IP settings then Use the following IP address and enter all that info. Except for IP address, change the last part to 254. If it already is 254, then pick any random number below 254.
You can also go in and Repair the connection. Click on the connection, go to the Support tab and click Repair. This will reset the IP but will not necessarily give it a different number.
Finally you can check your ip address at Ip-Details.com
Jan 20, 2011 | Linksys Wireless-G WRT54G Router
I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Mar 02, 2009 | Brother MFC 6490CW InkJet Printer
Connects to Access Point but the internet cannot be found
The main reason why you have this error message because your computer is not getting a valid IP address from teh wireless network, and the reason why its not getting a valid IP address is the wireless security or sometimes called WEP/WPA kay are not type in to the correct place, If you have a WEP enable on your wireless network you will have two option on the Linksys WLAN monitor where you can type in teh security key, you will see two boxes there when you try to connect to the secured network one says Passohrase and one says WEP key1 and if yuo have a wireless key that has a total of 10 or 26 key character you need to type that on the WEP key1 box leave the passphrase blank...But if it still didn't work you can contact this number for help 1-877-787-8749....
Oct 15, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
ASUS Eee 4G Notebook Logo
281 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
