Question about Whirlpool LSR5132PQ Top Load Washer
Whirpool washer wont agitate or stop filing with water
I was given a whirlpool washer that was bought new in 2001...
when you start the cycle will not stop filling with water until you push the knob in.. then when i turn the knob to next cycle it will not agitate.
will drain and will spin but when it goes to rinse again it will NOT stop filling the tub until i manually stop it..
HELP!!
  • soccermom13 Jan 10, 2009
    My washer is a heavy duty, super capacity plus. I don't know the model number. It will not stop filling up with water unless I push the button in and advance it. It will then only spin the water out instead of agitating. Same with the rinse cylce. Help.
  • 3 Answers
If that didn't work there is another possible solution... I had the same problem... and since I am cheap I like to make sure I try everything I can before buying parts... so heres what you do...
-Remove the front panel off the washing machine.
-Look on the side of the tub for where the pressure hose attaches to the base of it.
-Check for a build up of gunk in the hose near where the tube meets the tub... you'll probably notice wht looks like mildew... usually you can just pull it apart.
-I used pipe cleaners to clean out the end of the tube (you can usually unattach from both ends to make it wasier to work on)
-Now before you put it back together grab a can of compressed air and use it to blow down into where the hose connects (as there is usually a build up there too).
-Reassemble... TADA... if that fixed it you just saved yourself some $$$.
~~~~ Mittonman
Posted on Jan 26, 2009
  • 179 Answers
You need to replace your pressure switch
Posted on Dec 24, 2008
My Whirlpool Ultimate Care II LSB6300PW0 is about 6.5 years old. In the middle of a wash it started making a very loud humming noise. The machine wont agitate or spin. It still fills and drains the water...
Renee,
This might be too late for you but hope it helps!
I was able to fix a similar problem with the same model washer of a similar age so see if any of the following helps you.
Our washer died during a rinse/spin cycle and started making a horrific spinning/clicking sound when it was supposed to be agitating or spinning. It filled and drained like normal, and the horrific noise stopped when the lid was lifted.
Because of those two facts, I discovered it was likely the direct drive coupling, which connects the washer's motor to the transmission.
Turns out, that horrific sound was indeed the sound of one of the couplings spinning uselessly after it broke.
After some internet research, I discovered it was a simple matter of getting and installing the new coupling, which was very easy to do with a little professional help via YouTube:
Also, here is the website of a parts supplier with great schematics and great prices that I bought the part from.
Dec 22, 2010 | Whirlpool LSB6300PW Top Load Washer
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR5132PQ Top Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
