Question about Whirlpool LSN1000LW Top Load Washer
Won't spin heavy loads
My washer works fine other than if I have a heavy load it will not spin. It is starting to not spin now with a small load or no load at all unless I start it spinning.
It is an ESTATE super capacity by whirlpool corporation top loader
  • Anonymous Jan 02, 2009
    My washer is 2 years old and just stopped spinning?
  • 179 Answers
You need a new transmission it will slowly get worse until it stops working
Posted on Dec 24, 2008
Small capacity washer won't spin if load is slightly heavy; esp bath towels (standard sized).
possible motor is over heating from internal wiring failures or capacitor problems
call a technician for a check
Apr 21, 2017 | Washing Machines
Washer Spin Cycle doesn't work - sometimes
Hello T Wright - Based on the symptoms you are describing, it sounds like more than likely the unit is sensing an out of balance load, which could be too light or to heavy of a load, and the unit will not advance to high speed spin. However, often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 13, 2013 | Frigidaire GLTF2940ES Front Load Washer
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 07, 2011 | Whirlpool LSN2000LW Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 07, 2017 | Washing Machines
Whirlpool LSN1000LW Top Load Washer Logo
237 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
