Onda vx767 flash memory Lost-By clicking Reset Button
Hi,, I mistakenly clicked the rest button of my new Onda vx767 8GB Player. So that my internal flash memory lost. How can i ReConfigure to get back the internal memory.
SOURCE: Javascript code for Flash Button's click event
you need to create functions & your own defined set of commands and then call those functions with the flash custom made buttons.
it will work fine.
Posted on Feb 09, 2008
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
SOURCE: onda vx767 mp4
Hi. I have a 767 (Onda not Boeing :-) ) Mine has crashed like this a few times. Once the power drains to empty you should be able to start it after a charge. Sometimes pressing a pin through the reset hole will work, sometimes not.
Posted on Mar 25, 2009
SOURCE: How to call Javascript function on click event of Flash Button
try this:
create a button and in the actions window, add:
on(release){
getURL("javascript:myJsFunction();");
ensure you have the js function loaded into your parent page...
regards
Posted on Apr 09, 2009
  • 3 Answers
SOURCE: lost security code for my panasonic VD7003U DVD player for my car
press and hold down
Posted on Feb 26, 2010
Problem with V. 811 Onda Tablet
hi Akram.
this is all i could find out.
When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
Download the right firmware here: ONDA
Extract the content to the root of your sd card (since you cannot use your tablet, i suggest using a cardreader + pc or another tablet? or try to hook your tablet to the pc and hope it recognizes it)
There should be 5-6 files now on your SD card.
Turn on tablet while holding home button, untill white android figure appears then release.
It should update your firmware now...
or you could try this link on how to do a hard reset.
but do so at your own risk.
Onda V811 hard reset format factory mod recovery rom install ..
or try this link for more info.
hard reset tablet onda v811 Google Search
or this one.
811 Onda Tablet logo screen white Google Search
Nov 27, 2017 | Tablets & eReaders
Onda v711
You need to perform a hard reset on your Onda V711. Here`s how: You can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
If that fails, try flashing new firmware.
May 03, 2013 | Tablets & eReaders
I have a TDK 8GB , i lost my password , so i cant access to entire space on my disk,how can i totally format my flash memory?
Hello and Good Day!
Maybe this will help,first click start button located in the lower left corner of your desktop then click My computer, at the my computer window locate your flash drive perhaps it is labeled as TDK or removable drive then right click using your mouse,look the word "format" left click at the lower part of the window you'll see quick format click the box then click start.
Hope it helps Thank you
Jun 09, 2011 | TDK (CD-RW74HSFXS5) Storage Media
My SanDisk Cruzer 8 GB USB 2.0 Flash Drive SDCZ36-008G (new!)does not give in to formatting. Memory volume = 0, the flash drive does not open, but the operating system (Windows 7) considers that the...
Click on round windows button (on the bottom right) > right click on "computer" > manage > select disk management > if you can see the flash drive in on the right hand side right click on it > format.
Mar 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
If i turn my philips gogear on it freezes at 99% of the update, what can i do?
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If this doesn't solve your problem, please format the player. Connect it to your PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
*Contents may be removed by using these functions. So make sure to back up your contents.
You can also repair the player. You can download and install Device Manger software from your CD or from Philips support page to perform repair function. Launch Device Manager and click the Tool menu and select "Repair my Philips GoGear", then follow the instructions to perform the repair process.
This will surely fix the problem.
Feb 19, 2011 | Philips GoGear Flash MP3 Player
My 8GB SanDisk Cruzer when plugged in lights up, but it's not detected, both on Windows and on Mac, I don't know if it's still fixable... :(
Try reformatting your thumb drive. Here's how to do it on a Mac:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Feb 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Problem with nokia n95 8gb
Oops this doesn't sound good. Try following (hard reset) : push and hold the green button and 3 button and while holding them push power button until it restarts. If this doesn't help then back to the shop for replacement.
May 13, 2009 | Nokia N95 Cellular Phone
Formatting
try plugging it into your computer. go to my computer, and double click sansa 260 (or what ever yours is) then you should see a drive called internal memory, right click and reformat . You'll still lose your stuff tho.
Nov 08, 2008 | SanDisk Sansa e200 MP3 Player
Etrex - can't find satellites anymore. Just stopped one day after downloading Points to my pc
To my knowledge, a reset on a Garmin eTrex would require:
Holding down the PAGE and PAGE UP buttons while simultaneously powering the unit. The Garmin eTrex will enter the service mode/display:
- Bravo Version
- Software Version
- Time
- Internal temperature of unit
- Battery voltage
- External voltage
- Button presses
- Other tech info
You can also perform an LCD display/screen check by pressing the PAGE button 2X.
A firendly word of advice: While entering the service mode is interesting and useful, be careful which buttons you press because it is also possible to rest the unit to factory settings within this mode. Pressing "up"+"enter"+"on/off" keys in service mode will reset the eTrex to factory defaults. All presets and data will be lost.
To exit just turn it off as normal, and then turn it back on as normal. Unless you deliberately reset the GPS, nothing should have changed.
Alternately, you can try: Hold down the find, click-stick, and page buttons. Press the power button, and when the title screen appears, release the buttons. This will clear all memory (you will lose all waypoints, etc. back them up first).
Find button: bottom button on the left
Click stick: the button on the face of the unit
Page: the top button on the right
Power: the bottom button on the right
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 26, 2008 | Garmin eTrex GPS Receiver
Onda vx767 mp4
OK, so you plugged the car charger for the FM transmitter into your Onda player headphone jack perhaps? Yeah, that could cause problems. On the one hand, this player needs to be replaced. You can e-mail Onda by going to the crappy US version of the website - they seem small and they seem like custom-builders. On the other hand, they may have an inferior web page because there are no US contacts at all - they may all be Chinese. Most products have a warranty, but even better, most stores have a return policy. A US-based repair service would cost a minimum of $279.00, and that is assuming that they would be able to fix it (which they probably can't).
If you have already tried a reset suggested by the manual, and there is no "recovery" method listed in the manual (which would just be a version of what I gave you before, except they may suggest a button other than volume +), then I would go ahead and return it - sorry.
Jun 12, 2008 | Audio Players & Recorders
172 people viewed this question
 Grubhead
Grubhead
