Question about Canon PowerShot S1 IS Digital Camera
Battery problem Hello - I have been having problem with my Powershot S1 IS. I used rechargable Energizer batteries for it and have a matching charger. Lately - I have been putting freshly charged batteries into the camera and it would only hold the charge for a day or so of use (5 hours total) before pooping out. This problem has slowly gotten worse to the point I would put freshly charged batteries and it will immediately give me the "change batteries" message and shut down. I thought this may have to do with my charger and so I put fresh(out of the package) batteries into the camera and it died right away again. So - I am pretty sure something is wrong with the camera itself. What can be done? Will it be very expensive to fix? Thanks for any and all advice!
    Problem Solver:
  • 13 Answers
Hi. The most probable that the problem is caused by flash capacitor. To check if it is the case just follow the following procedure. 1. Turn on the camera (if you can not power it from batteries, try to use external 7.4V 2A power supply). 2. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 3. Turn off the camera. 4. Open and close the battery door. 5. Turn on the camera. 6. Take several pictures.
If after these operations the low battery warning does not show up it means that flash capacitor causes the problem and it should be replaced. Or you still can make pictures with your camera without using a flash.
Posted on Jun 19, 2008
  • 32 Answers
Did you use comapny authorised battery if not go for it
Posted on Apr 25, 2007
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Jun 20, 2014 | Canon PowerShot A480 Digital Camera
Can I use rechargeable batteries?
If it requires AA or AAA,yes you can use rechargables,or I guess any type battery which is made rechargable.They seem to last a little longer too.I am so disappointed how fast my digital camera eats batteries that I am trying to sell it and repair my SLR.
Good luck! Greg
Aug 12, 2010 | Canon PowerShot S1 IS Digital Camera
Display says to change batteries..have done and still says to change batteries
Strange as this solution might sound,m it works; clean the battery contacts in the camera, as well as the battery itself with alcohol. Even a small bit of oxidation, at the current level the camera requires, drops quite a few mvolts, enough for the camera to think your battery is running low.
Anand
Mar 05, 2010 | Canon PowerShot A710 IS Digital Camera
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
Battries dries out soon.
I've done a bit of research on this and am finding from my own experience with my powershot that it's the battery that is the issue. Not all rechargeable batts are equal. There are several cheap rechargeables that don't hold charges. Stick with a name brand battery. Canon makes brand batteries, Energizer etc... but I have found that the my cheaper batteries-even if they're rated a higher capacity, have been the let-down. It is an investment for the good batteries but it pays off when you don't miss the shots you want to take... K
Sep 02, 2009 | Canon PowerShot SX10 IS Digital Camera
Flashes low battery with only a few shots. Battery is new. Also what brand of rechargable batteries do you suggest?
cameras eat batteries fast. the best cameras have rechargable battery packs.
i'd use energizer or duracell. try to stay away from alkiline rechargables as they wear out fast. try Nickle Medal Hydrate Batteries (NiMH).
Aug 10, 2009 | Canon PowerShot A560 Digital Camera
A580 wont switch on with new correctly inserted batteries
Check for battery current ratings, Canon cameras need AA batteries with current rating above 1200 mAh, I use Energizer rechargeable batteries for my Canon Powershot SX110 IS. The batteries last more if we use the flash option wisely.
Jul 25, 2009 | Canon PowerShot A580 Digital Camera
My Canon S2 IS keeps saying 'change the battery' even if I put the new batteries in. Why...? Thanks.
there is a little coing battery located inside the battery compartment for the AA's. CR1220 you can get this at Radio Shack for about $5. If this battery is bad you will get the change batteries screen no matter how many fresh AA's you put in, Use a good quality alkaline battery such as the Energizer rechargable rated at 2700 mAh.
Jul 04, 2009 | Canon PowerShot S2 IS Digital Camera
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
115 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
