Question about GPS
I have a garmin nuvi 760, and I am trying to put mp3 files on it through an SD memory card. I have re-formatted the card 5 times, and my gps still isn't reading it. How can i fix this?
  • pmd6254 Jan 02, 2009
    I'm having the same problem as Molly. I've tried several solutions and none have worked. Things I've tried are..#1 creating a MP3 file and copying it to the removable SD card. #2 Copying the files to the internal memory. #3 Installing the MP3 using a reader/writer and then installing the SD card in my Garmin. I now waiting on a reply from Garmin.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Hsve you tried creating a directoy on the SD card called "mp3" and putting your files in there?
Garmin states.... The most common reason the GPS would not recognize the the audio files is the file format. The GPS will not read any file format other than the mp3 format, such as itunes (mp4) format, wave files, Windows media player files etc.... If the files will not read from from the internal memory of the GPS, the file format is the most likely cause......
Posted on Jan 03, 2009
NUVI 760 2010 MAP UPDATE ERROR CODE 2
The easiest solution is to put an sd card (8gb or less) into the sd slot. Have Garmin Express install to the sd card.
You can also do a hard reset and try to install to the device itself. A hard reset restores the files to factory default, so it may free up enough space.
May 09, 2017 | Garmin Nuvi 760 Car GPS Receiver
Will my itunes music library play on my Garmin nuvi 760? I dragged and downloaded my itunes music library onto my nuvi 760. When I hooked it up this morning to use it in my car it kept saying it was...
Your Garmin only supports MP3 files and iTunes is all MP4. The Best way to convert them is with "Real Player sp" Which is probably on your computer already or downlaod it for free. Open the music library and right click on the centre. There you will see "Converter" Select convert to MP3. Don't open iTunes. Instead go through; Start, my music, iTunes, library. This way you can drag a whole album into the converter. Plug your Garmin in with the USB cable and go through; Start, my computer, storage device H. At the bottom of the converter you can select where to send the converted files. Select the device H. Now press start and let it do it's thing. When it's finished you can see the old files in MP4 format with the new files in MP3 format listed under. Drag and drop is only a copy. You can delete all these files after to keep it tidy. All the original stuff is still safe and you Garmin should now have music on it. Try it with a small tune first to test. Best of luck. Regards Chris4fingers
May 31, 2009 | Garmin Nuvi 760 Car GPS Receiver
Device not reading sd card loaded music
try putting sd card back into a pc and check that the write protection is turned off. also if it has a write protection switch on the side of it it will need to be off. failing this. you may need to check what format the sd card was formatted in . it will need to be ntfs formatt not fat32. if it is fat32 ,save whats on it re format to ntfs then reload your files. try again.. cheers Phixxer.
May 24, 2009 | Garmin NUVI 360 GPS Receiver
Garmin nuvi 760, don't seem to be able to load music onto it
I have a 660, and it works fine from the sd card. Make sure the files are .mp3 and that you toggle the source from the mp3 player screen. Can you see the files in browse mode ?
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Loading mp3 files to garmin nuvi 350
The device is not recognizing the file name. The Garmin GPS will only recognize MP3 files. Ipod (MP4) and other media files will not play. Converting the files to the MP3 format will correct the problem.
Jul 25, 2008 | Garmin Nuvi 350 Car GPS Receiver
My Garmin nuvi 760 does not find any MP3 files on the SD Card Drive. It finds them fine if I put them on the unit itself but nothing on the SD card.
Was the SD Card formatted using the built-in format function of the Garmin nuvi 760? If, not pls try, if yes, pls try another card or the same card to another device that can make use of such type of memory card.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | GPS
How do you get SD cards to play ???
Are the songs in MP3 format? Typically you connect the GPS to the PC using the USB interface and using Windows Explorer, drag & drop the MP3 files into the GPS's MP3 subdirectory.
Then on the main screen, select travel tools and then the MP3 player. Select browse and choose a song.
Please let me know if I can be of further assistance to you.
- Jim
Feb 22, 2008 | Garmin Nuvi 660 GPS Receiver
Deleted MP3 files still play on my Nuvi 660.
Go to the GARMIN M3U file , open it and do what you want .Transfer, delete , copy and so so....
Dec 23, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
349 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
