Question about Zanussi 21 in. DCE5655 Free-standing Dishwasher
How to change the bottom door seal on a Westinghouse SB907
I can't see how to remove the old broken seal and put in the new one. The spare parts place said to unscrew the door panel. This seemed sensible so I opened the door and proceeded to remove the screws on the inside of the door, hoping the panel would give some room to get access to the seal. Instead the front white panel began to separate but I still could not get access. Do you need to unscrew the door from its hinges?
  • 236 Answers
SOURCE: Changing door hinge position
you could try and pop off the door seal from the w/m front and reach down to see if retrieval is possible.
Posted on Feb 16, 2008
  • 105 Answers
SOURCE: Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Posted on Apr 17, 2009
  • 42 Answers
SOURCE: my zanussi fitted dishwasher is leaking water
it has a pressure stut,that should tell it to stop filling the machine,it sounds like it has gone
Posted on Nov 03, 2009
TeepOrange
SOURCE: Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Posted on Jun 13, 2010
  • 10865 Answers
SOURCE: Hi, I need two upper
Hello. go to searspartsdirect.com and enter the model number. you can then order the parts you need. Joe
4 thumbs up please. ty.
Posted on Nov 05, 2010
I have model 7411-900 is leaking from the bottom ? May i have to right video to watch to fix the leak and this part i found broken when try to find the leak
First you have to find the leak. First place to look is the pump and its hoses. Often there is a removable panel at the front, or a cut out section at the rear. Then check the door seal. Pull the machine out and tilt it back. Put something sturdy under the front so it doesn't drop on you.
Google
make model spare parts
and you will end up somewhere like here. Unable to tell what your broken part is, but wholesalers carry or can order all of them.
Washing Machine & Tumble Dryer Spare Parts & Accessories ' eSpares
www.espares.co.uk/browse/ca1236/washers-and-dryers
For Tumble Dryer Spares and Washing Machine Spares you've come to the right place. Give your appliance a new lease of life with our huge selection of ...
Washing Machine Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts Washing Machine Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Washing Machine Shop ' Partmaster
www.partmaster.co.uk/washing-machine-parts/catalogue.pl?path=66991 Find Washing Machine products - repair your Washing Machine with a Washing Machine ... Get the Washing Machine products you need at Partmaster. ... Over 1 million spare parts and accessories from the world's leading brands including ...
Jul 03, 2017 | Washing Machines
The freezer door at the bottom of my Westinghouse French Door fridge won't shut properly on one side. It is 4 years old, it seals at the bottom but not the top.
Probably slipped off of track. Empty until light enough to completely remove drawer. Make sure guides are intact and reinstall properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Feb 20, 2017 | Westinghouse Refrigerators
My door freezer is broken how do i fix it
The best is to get the replacement door from Westinghouse if a tinkering job wont help or might look ugly.
Remvoe the old broken one and put in the new one with the fittings... hope the spare of this model is available!
Sep 28, 2010 | Westinghouse Refrigerators
Change door seal in westinghouse SB 907
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Jul 17, 2010 | Westinghouse 24 in. MDP531 RF...
How can I fit a bottom door seal on a Brandt dishwasher please. My dishwasher is leaking but the door seal and gaskets are intact although the sealant which held the gaskets in place has disintegrated....
If the bottom seal is definitely worn then it is quite a simple job.The seal is just pushed into a groove at the bottom of the door,as you pull the old one out be very careful as the edge of the groove is like a knife edge,the new seal will push in gently starting from one end and keep pushing into the groove try not to stretch the seal in length.Another thing to check first is check the bottom spray arm for splits on the edges as this could be directing the water onto the door,if there are splits then the arm will need replacing.
Hope this helps.
May 27, 2010 | Dishwashers
How do I actually get to the circuit board on dishwasher
Undo the top two screws on each side of the back of the door and all the ones across the top edge. Then the panel can be manouvered away from the door. The catch mechanism tends to hold the panel back and there is only just enough free length on the wiring to pull the panel away a couple of inches, but it's enough to access the on/off switch and control module.
Feb 10, 2010 | Westinghouse Dishwashers
How do I replace the door gasket on a Westinghouse front loading washing machine? Have taken off the front steel ring that holds the gasket in place, but looks like I need to take the front panel off the...
The step by step procedure to replace the head gasket are:
  1. Open door and pull on inside of gasket to expose screws or 1/4 nuts.
  2. Loosen[do NOT remove] all screws and pull old gasket out.
  3. Place new gasket in sink of hot water to soften it and put back around door.
  4. Snug up a couple of screws on each side and test seal by shutting door.
  5. You may need to adjust inner panel until just right..then tighten all screws
Sep 23, 2009 | Westinghouse Washing Machines
Jul 12, 2009 | Westinghouse Dishwashers
Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Jun 15, 2008 | Dishwashers
Zanussi 21 in. DCE5655 Free-standing Dishwasher Logo
157 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
