Question about HP Pavilion dv9000z Notebook
Hp dv9000 will not start up. blue lights are go
I have tried to start up the dv 9000 and all i get is a black screen and the blue lights flashing. i have tried fixing the problem by removing battery and AC power cord and holding power button down, then try to start it up to no avail. i then went on to pressing the F10 which done nothing. what to do???
You get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Posted on Dec 23, 2008
Hp dv9000 will not turn on the blue lights come on and goes off right away. I bought a new cord and adapter and it does the same thing. I did try taking the battery out and holding power button for 30 sec...
vast posts here on black screens of deathh
the screen is 100% black and never once shows text or that HP logo. 100% dead black, then that is the screen back lamps dead
as most long ago did, go dead , just not yours.
called the CCFL lamps dead.
ok the battery out test1
the other check is the fan is the fan blowing, it must or the CPU overheats fast and (it shuts itself off, like magic (intel inside)
see slide show here for Laptop link packup causes.overheated
http://www.pcdied.com/overheated.html
my guess is it is there, below... as all do every one at 20k hours.
see flash light test. there. on test one, do that.?
see test #1 (battery out, ac pack connected and working)
http://pcdied.com/black-screen.html#Basic-basics-101
if the flash sight trick passes, (see data) ask how to fix that
or read the service manual at HP.
see the list of HP , with CCFL here. dv9000 is it.
http://pcdied.com/monitors.html
if yes, ccfl dead
see here
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xdv-9000+ccfl.TRS0&_nkw=dv-9000+ccfl&_sacat=0
1% fail this way for inverter bad, 1 in 100.
see same page above for inverters sold the lamps run of it and it makes 500 to 1000vdc to do that,, HV inverter.
Oct 30, 2017 | HP Pavilion dv9000z Notebook
I have HP DV9000 laptop when i switch on it powers but the display is like in safe mood i cant see anything
i am mr john uche aaron
in Nigeria ,
my hp pavilion dv 9000
cannot bootup
but display only light on the quick bar
and blank screen
what is the solution
Dec 12, 2010 | HP Pavilion dv9000 Motherboard
Dv 9000 what lcd fits it
1) 17 inch WXGA (1440 X 900 Pixels)
Here's an example;
http://www.screentekinc.com/HP_Pavilion_DV9000_Series_DV9009NR--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Another one;
http://www.pcpartsltd.com/hp-pavilion-dv9000-screen-170inch-lcd-screen-p-1791.html?zenid=ihi8on44ad0gdnuab8ipt2ujb5
MAIN THING > Match the Part Number on the back of the LCD screen to the one you are going to purchase.
It isn't just whether the screen is the correct size, and dimensions. Whether it is a glossy finish, or matte.
It is that the cabling on the back of the LCD screen is correct, and the LCD screen matches the Inverter that is installed.
2) Just to add;
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
Nov 04, 2010 | HP Computers & Internet
At boot up I get the XP loading then stops. I get the blue screen of dealth. I placed the hard drive in another HP Pavilion dv 9000 and it works find. So, can I fix it or get a new motherboard
1. Try to clear all the dust by using blower and not sucking section. If possible use soft brush to clear any hard dust.
2. Try removing memory and replacing it after cleaning the slots.
3. Remove the processor and replace it in position, at the time of replacing even clean the heat sink compound and apply new heat sink compound.
After 1 and 2nd step try turning it on. It it does not help then only try the third step
Sep 05, 2010 | HP Pavilion dv9000 Motherboard
Hi, our HP Pavilion dv9310ca went blank last night whilst we were browsing the web. The hard drive light doesn't seem to be doing anything. When the power is on the auto fan runs intermitently. Ever so...
Your DV9000 has experienced what we call the black screen of death for most DV series laptops that have not had their motherboards serviced since new. There is a chip on the motherboard made by Nvidia and it controls a great deal of what happens on the 9000. This laptop has had a design and workmanship flaw since leaving production. The solder points on the chip are the weak link, it's not Nvidia'a fault, I would say it is the fault of HP for not listening to its customers and not realizing that they have failed the public miserably. Your motherboard has to be "reflowed" or replaced. It is cheaper to try and reflow the board, which is reheating the motherboard to allow the solder to flow and reconnect to all the connections on the chip. This usually does the trick 90% of the time. For the other 10%, the board will need to be replaced.
May 16, 2010 | Computers & Internet
My hp pavilion dv9000 17 power on but see black screen
If your 9000 is under two years old, you should contact HP customer care and have unit serviced under warranty.
HP has had allot of problems with the 6000 and 9000 units and in response has offered an additional year from date of purchase.
Its worth a shut. Doesn't cost a dime.
Hope this information has helped you.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
Everyb time I turn on my hp dv 9000 loptop the blue keys turn on but the monitor does not?
I have seen alot of dv9000 inverter or screen problems. Nice laptop but it does have its problems. I would check the inverter first, they are relatively inexepensive.
Aug 02, 2009 | Computers & Internet
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
HP Pavillion Dv 9000 stopped recognizing wireless networks.
make sure ya have a VISTA compatible Driver for ya wifi ... go to manufactures web site and DL latest one for VISTA..
Remove and reinstall most up to date driver... then use ya connection program to set it up.
Jun 23, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
504 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
