Question about Texas Instruments TI-30XA Calculator
How to clear all information from screen
Screen has (m3) in upper left corner, have not been able to totally clear screen.
  • Anonymous Mar 20, 2014
    Doesn't work - I can't clear M or E in lower left corner. I can't change settings displayed at the top. Examples:5/4,T,PRINT.
Screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
Posted on May 30, 2007
From TI web site:
The following will demonstrate how to clear the memory of the TI-30Xa or TI-30Xa Solar.
If a number is stored in memory on the TI-30Xa or TI-30Xa Solar, an M1, M2, or M3 will be displayed in the upper left corner of the display. To clear each memory location, follow the procedure below:
• If a number is stored in memory 1 (M1), press [0] [STO] [1]
• If a number is stored in memory 2 (M2), press [0] [STO] [2]
• If a number is stored in memory 3 (M3), press [0] [STO] [3]
Posted on Nov 06, 2007
Hold the ON Key and the CLEAR Key at the same time.
Posted on Mar 12, 2008
Ti 30x IIS displays memory cleared and will not do
Not sure but try
  • Press the "ON/AC" button to turn the TI-30Xa on. If the top-left corner of the display reads either "M1," "M2" or "M3," a number is stored in the corresponding memory.
  • 2 Press "0," "STO" and "1" if the number in the corner reads "M1." The upper-left corner should no longer say "M1."
  • 3 Press "0," "STO" and "2" to clear the "M2" memory. Pressing "0," "STO" and "3" clears the number stored in "M3" memory.
  • Read more : http://www.ehow.com/how_8623666_clear-memory-ti30xa.html
    Oct 14, 2014 | Office Equipment & Supplies
    I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
    In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
    - Turn off the device
    - Hold the upper-left corner of the screen while turning on the device
    - Release the power button when the Garmin screen appears
    - Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
    This should allow you to calibrate the screen. I hope this helps!
    Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
    M3 appears on the upper left corner of the screen. How do I clear it?
    It's indicating that you have a nonzero value stored in memory register 3. You can clear it by storing 0 into it by pressing 0 STO 3. You can clear all three memory registers by pressing ON/AC.
    Jan 14, 2011 | Texas Instruments TI-30XA Calculator
    Need diagram 2001 vw new beetle fuse panel. When I bought it did not have panel cover........thanks! problem with washer pump book says #1 10 amp small fuse and #24 20 amp no where on fuse panel says #'s
    The #1 fuse is in the upper left corner of the fuse panel, actually its the top fuse in the third row down, but row No. 1 and No. 2 do not have any fuses in the upper left corner. There are a total of 23 fuses in the upper most section. Fuse #24 is the first fuse in the lower section of fuses (upper left corner of that section as well.
    The block diagram for the fuse panel is also contained in Section 3.2 of your Owner's Manual. The fuses are numbered in each section from top to bottom starting in the upper left. Fuses 1 thru 23 in the top section, fuses 24 thru 44 in the bottom section which consists of three columns.
    Oct 28, 2010 | 2001 Volkswagen Beetle
    I have the symbols M1, M2, and M3 on my top left corner of my calculator. How do I remove them?
    They're telling you that you have non-zero values stored in M1, M2, and M3. To clear any one of them, store 0 in it by pressing 0 n where n is 1, 2, or 3. To clear all three of them at once, press ON/AC.
    Oct 06, 2010 | Texas Instruments TI-30XA Calculator
    I have a ricoh 1045 , and I can not read the display looking down, but I can see everything in an angle. Can you help?
    See the display panel contrast button position(in the left side to user tools button.).If not work perform the touch screen adjustment:Press the total stop key(yellow)-1-9-9-3-clear/stop key(red button) x5 timeand press enter key(double croice).The graphic sensing adjustment screen will appear.Touch the upper left corner then the lower right corner of the panel using a pointed tool.Touch a few spots on the LCD and confirm that the marker appear on the screen at exacrly the same location as the pointed tip.Touch enter on the screen adjustment.Turn off the machine and back on to store the settings.
    Sep 26, 2009 | Ricoh Aficio 1035 Copier
    TI 84 plus calculator, flashing dot in upper left hand corner
    When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
    Try this simple operation
    [1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
    Hope it helps.
    Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
    I have a Sony Trinaton XBR about 6 years old. Works great. Have Comcast cable and they recently installed a new cable box. Now I get all cable channels on "Video 6 - DVD" rather than "Video 7 -Cable Box"....
    I was awaiting your response in chat session but could not get any thing.
    Please hook cable box in Video input-7 instead of Video input-6 in TV and select Video input-7 with remote on TV.
    Regarding continues on-screen display of video-6, press Display button on TV remote once, on-screen display will disappear.
    Thanks.
    Jul 12, 2009 | Sony Televison & Video
    I can't get Video 1 off in the upper left corner of my Sony Wega TV,
    Contrary to some opinions, you totally can. You only need to locate the "display screen information" button on your remote (on mine, it is at the very top, second on the left) and hit it once. Screen information will disappear. It took me a while to figure this out, but I am relieved that it eventually worked
    Jun 06, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    TH-50PX60U picture problem
    Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
    Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
    Texas Instruments TI-30XA Calculator Logo
    3,195 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Steve Allison
    Steve Allison
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
