Question about Canon PIXMA MP150 All-In-One InkJet Printer
Epson Stylus R2400 Waste Ink Pads Full
Is there a way to reset waste ink for this printer?
  • 30 Answers
You need to download the SSC Service Utility from the following site http://www.ssclg.com/epsone.shtml you will find all the information too :) Merry Xmas!
Posted on Dec 23, 2008
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
How to change waste pads on Epson R2400?
The R2400 is quite an expensive printer and changing the pads would likely knock the printhead out of gross alignment so if you really must change the pads then I'd recommend getting it done at a service center (much as it pains me to suggest it).
The only time it's really essential to get the pads changed though is if you do a lot of borderless printing as this dumps ink straight to the pads and bypasses the popular external waste ink tank modification.
My recommendation would be to consider getting the printer serviced this once and then immediately install an external waste ink system to your printer and use the SSC or A10-IPR utility from Epson to reset the waste ink counter from there on in.
All the info you need is available via this link
Hope that helps, even if it is a little late..
Mar 19, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson r 2400 top trashcan light and ink light flashing
For Jane106:
The ink-out and paper lights flashing alternately indicates the "service required" or basically ... "change my ruddy diaper, it's full of ink".
This is not as bad as it sounds and you have a few options:
1. Take it to a service center and have it serviced (ie: have the waste pads replaced)... It's expensive though so be warned.
2. Download the SSC utility (Google: SSC epson reset) and use this to reset the protection counter in the printer memory.
Note: READ the manual, it's not overly intuitive.
If you've gone with 2. you'll still need to do something about your waste ink and the simplest is really to modify your printer to redirect waste ink from the cleaning pump to an external tank.
Again Google is your friend so keywords like "Epson waste ink R2400" will find what you need. Some kits are better than others but then I'm biased :)
Hope that helps.
Jan 15, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
441 people viewed this question
old marine
old marine
