Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
L60AT wont relight
My L60AT shut off and when it tryed to relight the burnner light blinked and so did the yellow medium light and the it went to code EE2. How do i fix
    Novelist:
  • 126 Answers
EE2 means no ignition. It could be No fuel or low fuel, dirty filter. You need to look at the flame when you try to start the stove. If you have flame then the igniter is good. If there is no flame and a bumping noise you have a fuel problem. No flame and no bumping you may have an igniter problem. Feel around the burner pot to see if it gets hot. A bad igniter will lead to a flooded stove if you continue.
Tom Hawkins
Bethel, Alaska
Posted on Jan 06, 2009
Toshiba 46 inch regza1080p wont turn on. it clicks,yellow blinking light at front
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 28, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dometic Fridge 2652 will not stay lit or relight in gas mode
check house batteries needs 12 volts to control board
Jul 13, 2012 | Dometic RM2652 Refrigerator
Lights on the panel blink
The only thing I can think to try is shut off it's breakers(breaker box or in some places fuse box) for about a minute then turn them back on. This usually will reset the microprocessor. If problem persists I would call a repair tech as it probably is circuit board unfortuneately. Please let me know how it goes.
Regards,
Dec 15, 2011 | Maytag Dryers
System shuts off and yellow light starts blinking
you'll have to send it to sony for repair. as of now there are no ways to fix this yourself.
Apr 25, 2010 | Sony PlayStation® 3 (80GB) Console
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Replaced lamp worked for a few days and now it wont power up, now when you turn it on the light blinks green and then the yellow lamp light comes on and no sound or picture.
when the set shuts down check to see what the error code is, press the input and menu buttons at the same time, hold them down for 10 seconds, the green light should blink a two digit code, if this is 38 then you have a thermal sensor problem and need to call Mitsubishi for extended warranty repair.
Sep 08, 2009 | Mitsubishi WD-65732 65" Projection HDTV
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
158 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
