Question about Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
Panasonic SA-HT930 INIT problem
The subwoofer main unit of the Panasonic SA-HT930 got unplugged while the DVD/Receiver was on and now when I turn it on it just says INIT. None of the buttons do anything except for the Power button which changes the display to WAIT then it says GOODBYE and turns off. Any way to reset this thing or make it work properly again?
  • 1 more comment
  • murraydeluxx Jan 10, 2009
    Whenever I turn on my Panasonic SA-HT930 unit, all I get is the 'INIT' message.
  • Anonymous Apr 04, 2009
    Same problem here.
  • Anonymous Apr 11, 2009
    same deal, i cannot believe theres no solution
SOURCE: Panasonic SA-HT930 "INIT" Message
I have that problem after an electrical short out.. wow, nobody knows how to solve it?
I hope somebody can fix this problem
Posted on May 31, 2008
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
SOURCE: Panasonic SA-HT692
Thanks for your help, but I couldn't wait any longer and took care of the problem. This is what I did to fix it: With the dvd player unplugged, I removed all the screws and opened up the dvd player to make sure that there was no dvd stuck inside. Once I confirmed that there were no obstructions, I then proceeded to plug in the dvd player so I can see how the player reacted to the error messages. I noticed that every time I pressed the eject button, the section where the sensor reads the disc was slightly moving but not fully reacting. So right above the laser sensor apparatus, there's a white plastic circular piece and I moved that around a few times and it did the trick. Problem solve, the dvd player is working like a champ. Hope this helps if someone out there that has the same problem.
Posted on Feb 13, 2008
  • 208 Answers
SOURCE: Tray won't open!
Hi, not being too familiar with this model ( i.e. whether a single disc or 5 disc changer). it sounds like the CD player section is trying to find home position and will not continue until it has done so. It is very likely that there is a disc in the mechanism and depending how competent you are with a screwdriver, you may be able to release the disc either by removing the top cover or check on the underside of the machineto see if there is a hole in the bottom where you can wind the cd mechanism to the eject position.
Posted on Feb 07, 2009
Panasonic f61 output
If what you identify as the output IC has failed, one or more speakers would be affected.
Nov 23, 2013 | Panasonic sa-ht930 Home Theater Audio...
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
Panasonic Surround Sound system Displays "INIT" and Disc tray will not open
it is the problem of cd changer mechanism and company have 1000 reasons to blame the user.
May 31, 2009 | Panasonic SC-HT930 System
I cant eject cd/dvd changer.
there may be a lock/unlock selection in the menu somewhere, something like a parental lock on tv sets, this is just a thought on my part.
Mar 25, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic dvd home theatre SA HT690
contact panasonic customer service and tell them the model# of the sub , just tell them you need a replacement , they will ship it out to you at a reasonable charge and sometimes they,ll send them out for free if the unit was just purchased because you can tell them it was,nt with the unit and that always seems to work for , Hope i was able to help and if you think i was helpful please leave a nice rating Thank you sincerely glenn mayer
Mar 04, 2009 | Panasonic sa-ht930 Home Theater Audio...
Reciver shuts off
Check your speaker and sub connections. When they are not imputed correctly the system will shut off.
Jan 10, 2009 | Panasonic sa-ht930 Home Theater Audio...
Unlock DVD SA HT930
My husband just unplugged it for 30 secs then plugged it back in and it unlocked.
Apr 10, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic home theatre system 5 cd changer says no play when inserting dvd
Try cleaning the pickup with a cleaner disc-i'm assuming this unit IS supposed to play DVDs, of couse!
Stan
Mar 19, 2008 | Panasonic sa-ht930 Home Theater Audio...
581 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
