Question about Zenith IQC50H94W 50" Rear Projection Television
Iqc50h94w projection tv
On the deflection power supply there is a part about the size of a resistor (yellow with an orange stripe ) on the print it has 7 k protector labled for it is this like a fuse if so where can i find this part and what is it called i have serched for 7 k protector and came up with nothing the part is reading open on EP98
    Problem Solver:
This is called a pico fuse.
Posted on Aug 10, 2008
I have a 2000 zenith 50" projection. Model #
That is hard to say without diagnosing the problem and knowing what is wrong. Call a service center and askthat question there would be best and esasiet
Sep 21, 2014 | Televison & Video
I have a HDTV 524159 RCA, it has an hour-glass effect on both directions. On the left side, it hour-glass inward with red and yellow stripes and on right side blue and light blue stripes. It hour-glass...
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
Deflection circuit board has gone out 3 times in 2 years part#ue25952 why?
you have a shorted resistor in your power supply section feeding your board check the schematic and, reduce the too-high voltage in one or, more wires at the deflection board by placing the appropriate resistor(s) in the offending wire(s.)
Aug 21, 2009 | Hitachi 51F59 51" HDTV Projection...
I have a Zenith Projection 50" TV IQC50H94W that has a blue arc
You need to replace your STK392-150 I.C.'s, Also, check all of the large nearby resistors, make sure none are burned, and remember, you have to check the resistance out of circuit with a meter.
once the resistors are checked, and the convergence I.C.'s replaced, you should be able to converge the picture through the user menu.
Dec 18, 2008 | Zenith IQC50H94W 50" Rear Projection...
Resistor identification
Hi fccjben;
The color code is as follows: blk = 0; brn =1; red = 2; orange = 3; yellow = 4; Green = 5: blue = 6; violet=7; Grey = 8; white = 9
Unfortunately, if it is wirewound, they usually printed the resistor value on the body of the resistor. For sure it shouldn't be glowing. Sorry I can't be more help, but without a schematid, can't do much else
Good luck Loringh
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Nov 10, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
May 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Zenith IQC50H94W Color Loss
check the 180 volts that is the supply of the CRT Grid.
Oct 03, 2007 | Zenith IQC50H94W 50" Rear Projection...
Zenith IQC50H94W will not power up
First off, check Q655,EP98,and D756. If they all check good it may take a service manual to troubleshoot this set which is based on the Hitachi DP-05 chassis and is similar to their model 53FDX01B.
Jan 24, 2007 | Zenith IQC50H94W 50" Rear Projection...
IQC50H94W Zenith Projection tv
check the flyback/hv-spliter sounds like it could be your problem also check horizontal ic
Jan 23, 2007 | Zenith IQC50H95W 50" Rear Projection...
Zenith IQC50H94W 50" Rear Projection Television Logo
78 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
