Question about Premiere Ranges SCK34 Gas Kitchen Range
My premire gas stove top clock and timer went out what do i have to do to get it back on
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
Magic chef model# cer3725acw. Using stove top burner.(CAL) Error message came on briefly on touch pad display window. Can't change time on clock,turn on oven,set temp.or timer.Burners work fine. Unplugged...
It sounds like a bad control. Before replacing the control, make sure it is not in Sabbath Mode, Child lock and if all else fails try resetting the control to factory defaults. If none of these work then replace the clock/control part number 5701M827-60. This part runs about $175.00
I attached a cut out of the service manual, to show how to reset the locks and factory defaults
May 27, 2010 | Magic Chef Kitchen Ranges
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Dec 30, 2008 | Kitchen Ranges
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Premiere Ranges SCK34 Gas Kitchen Range Logo
24 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
