Question about Sony Ericsson XPERIA X1 Smartphone
Touch Screen is dead on my xperia!! Help plz??
Hey Guys!!, I just got a new actually second hand Xperia x1 from one of my family relatives and was in really good condition during his use but it accidentally fell from him and now its touch is not working!!!! any help would be greatly honored! i wasso excited to get the mobile but unfortunately..... so plz???
    New Friend:
Digitizer is busted. You can try to pull it apart using a guitar pick and check the ribbon cable, but it's probably a goner. Sorry for your loss, touchscreens hate falls.
Posted on Dec 21, 2017
SOURCE:
zohail
  • 1223 Answers
SOURCE: Repairing (replacement) Sony Ericsson XPERIA X1 LCD Display
All these videos below will help u in ur task
http://www.youtube.com/watch?v=pO2GSMb3aWM
http://www.youtube.com/watch?v=RHMKchQeOdQ
http://www.youtube.com/watch?v=V0sOaIo6724&feature=related
Pls RATE ME WELL !
Posted on May 28, 2009
  • 21 Answers
SOURCE: Sony Ericson Xperia touch screen keeps freezing,
Had someone else with the same problem, it's similar to a PC locking up when it is performing too many operations at once and the processor gets tired of waiting for ram to provide info. He deleted alot of old applications, contacts, and anything that is old or not needed. Then he took out the battery and reinserted it and it works fine. Not sure if it will work for your Sony, but it's worth a try. If that doesn't work you may have to do a reset on the phone. Good luck!
Posted on Nov 09, 2009
  • 154 Answers
SOURCE: i will like to change my xperia x1 phone language
Tap the windows start --> Settings --> System --> Regional Settings, on the Region tab, select your Language.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more.
Posted on Apr 21, 2010
  • 318 Answers
SOURCE: X1 XPERIA LOCKED NOT SIM BUT PASSWORD
Do a hard reset on the phone and that will restore it to its factory default:
While the phone is off -hold down the front left and right buttons on the X1 and insert your stylus into the soft reset hole all at the same time.
After that you will see a blue screen says to press R to reset and delete all my existing stuff. Then you will have to calibrate the screen
www.usedcellphoneshop.com
Posted on May 25, 2010
SOURCE: I want to install arabic
i need to install the arabic language
Posted on Dec 21, 2010
My sony xperia tipo(DUAL) touch screen freezes after every 15-20 minutes of standby . plz helpp !!!!
There is a solution by Sony for this problem.
Just follow the instructions: http://talk.sonymobile.com/t5/Xperia-miro-Xperia-tipo-tipo/TIPO-TOUCHSCREEN-FIX-PATCH-HERE/td-p/262920
Sep 27, 2013 | Sony Xperia Tipo Dual ST21i2 Black Android...
Tip
You may use Nidesoft Sony XPeria Video Converter.It is excellent Movie Converter...
Sony HDR-SR10E,Share Sony HDR-SR10E MTS to FLV for Mac Users
Do you have some short films shot with Sony HDR-SR10E AVCHD camcorder, and want to share them on your website? It will make your site more attractive with videos. While Apple compete with Adobe, the Flash support on Apple devices like iMac, MacBook Pro do not support exporting to Flash FLV/SWF now. You can not directly export FLV from the Apple QuickTime Player, iMovie or Final Cut Pro/Final Cut Express.
One solution is to upload videos to YouTube and embed YouTube videos on your site. If you do not want to embed YouTube videos, you can convert Sony HDR-SR10E MTS files to FLV with Mac Sony MTS converter, and put the FLV videos on web server with Flash player. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Sony HDR-SR10E MTS converter for you. It exports Flash videos with automatic deinterlacing function, which makes the FLV videos play without interlacing artifacts. It could also help you merge several Sony .mts video clips and export as one file.
Here is the step-by-step guide to convert Sony HDR-SR10 videos to Flash on Mac.
Step 1. Load Sony HDR-SR10E videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR10 converter, and click the "Add" button to load .mts files for conversion.
Step 2. Choose Flash FLV output format.
Click the "Format" option, and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. You can also choose the profiles like FLV H.264(*.flv) or F4V(/f4v).
Tips:
With The above mentioned output, you shall use Flash player like JW player, Moyea PlayerBox player, or Flow player to play the Flash videos. If you want the video to play automatically, you may choose SWF-SWF Forma(*.flv) as output.
Step 3. Transcode Sony HDR-SR10 MTS to Flash.
Click the "Convert" button under the preview window, and the conversion from Sony MTS to Flash video FLV/SWF will start right away.
Wait for a while, and you can upload the Flash videos to your sever and embed them on your web page.
PS:
1. The "Merge into one file" on the main interface is to join/splice .mts files.
2. If you are using camcorders like Sony HDR-CX350, HDR-XR520, HDR-TG7, or Cyber-shot DSC-TX7, DSC-H5V, you can also use the Mac Sony MTS converter to export FLV files for web sharing. Aunsoft MTS/M2TS Converter for Mac also works with Canon HF S21, Canon HF100, Panasonic HDC-TM700 and other AVCHD camcorders.
on Jul 23, 2010 | Cameras
Cant align screen..help plz..show me the way..xperia x1
my phone showthn screen and masage tap the target firmly and accurately ateach location on the screen .The target will continue to move until the screen us aliged
Feb 02, 2011 | Sony Ericsson XPERIA X1 Smartphone
I dropped my phone today i switched on and everything was working besides the touch screen ..please help
Please switch off your Sony Ericsson XPERIA X1 phone and putout the battery from phone after few minuts again insert the battery into the phone and switch on it. I believe your problem will be shout out.
Vinay
Dec 03, 2010 | Sony Ericsson XPERIA X1 Smartphone
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
May 25, 2010 | Sony Ericsson XPERIA X1 Smartphone
I have sony ericsson xperia x1, i have forget my password, how can i open my xperia, please help me.
go to sony ericsson website then update your phone software but since you can not open your phone all data that were saved in your phone will be deleted but then your phone again.. it's up for you to choose.
Oct 29, 2009 | Sony Ericsson XPERIA X1 Smartphone
Touch screen is not responding on my x1
ur TOUCH PANEL IS FAULTY kindly go for warranty claim or tell me i can give u link for the out of warranty replacements
Mar 16, 2009 | Sony Ericsson XPERIA X1 Smartphone
Sony Ericsson XPERIA X1 Smartphone Logo
42 people viewed this question
Top Sony Ericsson Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
