Question about Toshiba Satellite A85-S107 Notebook
Problem with display
I was given a Toshiba A85-S107 Laptop. It had not been used for a year or so. It is run by Windows XP Home edition. After running for sometime, the LCD display turns black, as if the display have lost its light or illumination. The scenario is like, the LCD display is running but there is no light in the LCD.
  • 74 Answers
It's the inverter you need to change.
Usually that's the symtoms when it goes.
You can usually find one on ebay or amazon or wherever it's not very hard to change either.
Just has a couple of plugs and they are affordable.
Posted on Dec 24, 2008
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Ethernet controller I need one please
Here is the link from Toshiba site
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1042296&rpn=PSA82U&modelFilter=A85-S107&selCategory=3&selFamily=1073768663
Select your Operating System and in categories select "LAN" download it.
If you are using windows xp with servicepack 2 or 3, here is the link.
http://cdgenp01.csd.toshiba.com/content/support/downloads/sa85lanx.exe
Dec 17, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite a85-s107 disc drive not working. drive opens takes cds and acts like its reading them but the program never opens
google search a downloaded program called CD BEGONE...run it..reboot pc.
if that does not cure problem....buy a replacement drivefrom ebay
Sep 15, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite a85-S107 the volume control wheel on the computer does not turn the volume all the way down. I can still control it through windows. Help!
maybe your driver is not working well http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm go to this site you can find drivers of toshiba there. reinstall some of your not compatible drivers.
Aug 06, 2009 | Toshiba Satellite A85-S107 Notebook
How do i disable programs from startup or goto default startup?In a Toshiba Satellite A85 Win XP
Type
MSCONFIG in the run box, go to the startup tab
Set as you wish here
Regards
Richard.
May 19, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop black screen
chek in bios setup your hard disk is detect or not.
when u power up the laptop press F2 or DEL or F5 or F12 then u see bios menu.then if your hard disk not detect disable sata.if u detect your hard disk set harddisk as first boot device then save settings.
but if u see first windows then blank scrrreen u need to do nothing.just do following.
when u power up the laptop press F8 key then u get safe mode and etc menu.
go to enable vga mode thwen u enter in windows xp set your display resolution to 800*600 or 1024*768
thats all.
Nov 10, 2008 | Toshiba Satellite A85-S107 Notebook
Problem running the restore disk for Toshiba A85-S107
I have the same model and i just reformatted the hard drive with the original restore disk and it does loop around several times. That is the way it is suppose to do on this particular restore disk. So don't be afraid if it goes around several times because it is doing different tasks each time it loops.
Nov 19, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
