Question about Duke 613Q-G2ZX Gas Double Oven
Help my oven is commercial ,it is not working ,the only thing i know it is double door ,use for gas ,so can you help me
    President:
  • 704 Answers
Without much to go on, I would suggest you contact the manufacturer for a detailed troubleshooting guide and to request a manual. I have provide a link to the manufacturer for your use to either email or phone them for further assistance. Best of luck to you.
http://www.dukemfg.com/contact_us.html
Posted on Jul 13, 2009
  • Duke Master
  • 3,463 Answers
Hi there.
I am unfortunately able to help you with your oven problem, as I have no experience with gas ovens..Suggest you find an expert who is fully coversant with gas ovens..
Once again sorry, and good luck with your oven. Thanks for asking anyway.
Have a nice xmas.
Posted on Dec 23, 2008
Where do you get the double sided tape to stick the glass door back on oven door?
Far as I know the glass oven door is sealed with special silicone putty that is resistant to a temperature of 300 Celsius .
Previously, the required perfect clean the surface with alcohol.
Dado
May 23, 2014 | Electrolux EOG9330 Gas Double Oven
Convert dfg200 from gas to lp
being this is a commercial oven you will nee3d to go to a commercial parts purveyor to get the conversion parts,on residential units the orfices are included with the range when new for conversion at any time,the gas orfices need to be changed on the top burners,then the orfice spuds in the oven bake and broil units need to be turned down onto the orfice for conversion,your commercial parts person will have the steps with the conversion kit to do the change-over
Nov 24, 2012 | Blodgett DFG200 Stainless Steel Gas Double...
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
How do I clean a Wolf gas oven? Can I use commercial oven cleaners?
Wolf does not recommend use Easy Off, but this is the best cleaner for oven, just don't spray on it, wear gloves, spray on a rag and apply on to the porcelain surfaces, and other good all around cleaner is called Bar keeper's friend and you can pick it up at Safeway or ACE Hardware. Have fun.
Dec 31, 2009 | Wolf Range WKGD-2 Gas Double Oven
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
I need parts for a old covection oven made by hobart it is a large stack with no model # commercial stainless any suggestions
Remove the lower panel under the doors. You should find the data plate on the back of the panel. What country are you in?.
Feb 24, 2009 | Hobart DEC502 Electric Double Oven
How to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Jan 16, 2009 | Wolf Range WKGD-2 Gas Double Oven
Duke 613Q-G2ZX Gas Double Oven Logo
195 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a Duke Oven Expert? Answer questions, earn points and help others
