Question about Sunbeam 4237 / 4238 Iron with Auto Shut-off
Electric Blanket Control Blinks
The control of my electric blanket blinks and the blanked won't work.
I tried disconnecting it but when I plug it back on the blinking resumes.
This has happened to me twice before with prior blankets so I am afraid to buy another Sunbean blanket.
  • mrhcrh Jan 27, 2009
    I unplug, it worked for awhile but it happened again.. it flashed FF  what does this mean???
  • dufferdavid Jan 27, 2009
    I have the some problem and it is only 3 months old.
Mydual control sunbeam electric blanket blinks on one control
Posted on Feb 22, 2009
I AHD THE SAME PROBLEM. I UNPLUGGED THE CORD FROM THE BANKET ITSELF AND THE RECEPTACLE. PLUGGED IT ALL BACK IN AND THIS SOLVED MY PROBLEM. HOPES THIS SOLVES YOUR PROBLEM.
Posted on Jan 17, 2009
    New Friend:
Used to work but doesnt anymore. I bought it for Christmas of 2015 and it no longer works. The blanket was great at first but it gradually stopped working. First it would stop heating in some places. Then most of them and then it finally just stopped working. The controller would start blinking error messages "E2" , "E" and "E3". I can't get it to stop this, and now the controller doesnt even turn on
Posted on May 02, 2016
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Blinks and doesn't heat.
Could be a loose connection or a damaged cable. Try gently moving the cable and see if it starts to blink etc?
How old is it? Is it still in warranty Guarantee? If it is, take it back to where you bought it from and they should repair it or replace it.
Failing that you may have to buy a new one. Wallmart or similar have cheap electrical appliances
Aug 03, 2009 | Irons
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
My dual control sunbeam electric blanket flashes on one side
Return this product as it is a fire hazard.
please mark this as a fixya! thanks
Feb 22, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
The controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
Oct 07, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Blinking red light
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Sep 06, 2008 | Irons
Red Light Blinking
heatman101
Jun 11, 2008 | Krups V70 Iron
Sunbeam 4237 / 4238 Iron with Auto Shut-off Logo
4,422 people viewed this question
Top Sunbeam Irons Experts
Craig Butler
Craig Butler
Karl H
ray gallant
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
