Question about HTC Touch P3450 Smartphone
Hi iam Using HTC3450 , iam facing some problem with my touch screen on the right side of the screen iam able to use my touch screen but on the left side iam not able to
How to update htc 6.1
Posted on Dec 23, 2008
When a patient is touched on both sides of face simuntaneously patient report the feeling of touch on right . when the face is touched one side at a time the patient reports a touch on correct both on...
umm...WHAT?!?!?!?!? This doesn't seem revlevant to a website, nor does it seem like a question, but more of a statement/complaint...We're FixYa, not the doctors health Network...
Jan 08, 2011 | Computers & Internet
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
Touch screen does not work
The problem is a faulty contact from the touchscreen leading to the phone board.On the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screens face a little from the phone body exactly at the volume down button(using ur fingernail or something).Use thin knife ..Gently stick a knife in just to the side of the touch screen and then push the knife away from the the screen so that it looks like the screen is going to pop out, this should then re-establish the connection between the screen and the phone board.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Jul 28, 2010 | Samsung Omnia Cell Phone
Touch screen letters inop on right side. Also when I try to scroll on left side it selects a street instead.
try to calabrate the touch screen if it dosnt work replace the touch screen part# CSX1085
Jul 22, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
Not switched on
i think it should be coz many softwares installed and running out of memory .. i was facing this problem and i formated the memory and very less s/w installed ..
May 25, 2009 | HTC Touch P3450 Smartphone
On my gps when i touch the left side of my screen the right
is there a callibration option ? if so it may just need callibrating for touch screen again.
May 14, 2009 | Tomtom ONE 3rd Edition GPS
Jensen vm 9412
If you have already done a recalibration on it, and it's still not working, I'm thinking the touch interface is hosed a little more than you can handle on your own - it may have to be sent out to be repaired. It seems like that right-side portion of the touch panel is just plain worn out. I don't really know of any other way to try and bring it back - you might contact a Jensen dealer and ask if there are any product recalls for such defects though - if this has happened on a large number of the head units, they may issue a recall or at least partial reimbursement for the cost of repair. At this point though, a service dealer will be your best bet.
Aug 01, 2008 | Jensen's VM9312 Car DVD Player
HTC Touch P3450 Smartphone Logo
51 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
