Question about Dell Inspiron 6000 Notebook
Internal Wireless card will not activate
We had to re-format the hard drive on the Inspiron 6000 and now that XP is reinstalled, the wireless network card will not power on. What could we have missed?
Most likely you need to install the driver for the NIC card. Go to Device Manger under System Properties and see if the Wireless NIC is showing a driver error. If so right click, select Update Driver and navigate the the file on the CD. Once the driver is installed if should function normally.
Posted on Dec 27, 2008
Need to reinstall program that manages my network adapter---how do I go about it? I have a dell inspiron laptop-windows xp. Thanks in advance.
You don't really need one as you can use the windows wireless config utility.
If you have an internal network card then go to your manufacturers website and download the drivers from there.
Sep 04, 2010 | Dell Computers & Internet
Just put a new hard drive in my Dell Inspiron 6000 laptop. I get an excellent signal when connecting to the wireless router, but I get a limited or no connectivity error and cannot access the internet on...
is it only in one location or everywhere, if only at home reset wireless router. if evrywhere, then uninstall wireless driver and llet windows reinstall it by rebooting
Jun 19, 2009 | Dell Inspiron 6000 Notebook
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
Hard Drive crash-reinstalled XP results in No wireless or sound
Does your device manager show that you have a wireless network card? If so, you turn it on and off usint the Fn + F2 buttons together. If you need the driver, go here to choose which one you have, and download it.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid=
New driver should do the trick on the audio, so why don't you go here to download it.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R99254&SystemID=INS_PNT_6000&servicetag=&os=WW1&osl=en&deviceid=6466&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=128550
Mar 15, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
TAKING TOO MUCH TIME TO OPEN. THE HARD DRIVE LAMP RUNNING CONTINUOUSLY
Hi!
Have you ever tried reinstalling windows xp before? if not then revert back to me. I'll teach you how to check if the system still has PC restore. If you ever have tried reinstalling windows or your hdd has been replaced, then you may need to reinstall windows manually by using the discs.
Hope this helps.
Karlox™
May 18, 2008 | Dell Inspiron 6000 Notebook
Bluetooth technology.
Hi
Inspiron 6000 is compatible with Dell Wireless 350 Bluetooth Internal Module.
Check the link below for location, information and illustration
http://support.dell.com/support/edocs/systems/ins6000/en/sm/blue0.htm#wp1000550
Mike
Apr 19, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
473 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
