I have a linksys WMP54G adapter with a D-Link DIR615 router.
I have tried to set it up using WEP, WPA-2, anything but when I do this, it cannot find the access point. However, it allows me to go unsecured network and I can easily access the internet. Of course this means everyone else can also access my network and internet in my range.
I uninstalled the linksys driver, reinstalled it, tried to set up my network again to no avail. I have hit the reset button on my D-Link Router about 45 times. I am lost, please help if you can.
-   maybe this is my problem, how do I log onto the wifi router? My manual tells me to go to 192.168.0.1 but I keep getting results from google or a page cannot be displayed option. Do you know what i might be doing wrong?
I do only have the one computer,and the router is not wired to it - i have it set up at the other end of the room attached to my cable modem.
log onto the wifi router. set your ssid to whatever you want it to be and security to whatever p/w you want it to be. this will usually require a reboot. this will need to be done on the primary pc
if you only have one. connect it all physically as it should be. then do the above. disconnect the compuer from the ethernet cable and it should be a wa-la. hope this helps :)
I use to be able to use wireless linksys but lately received unauthorized access errors at a few...
(More)
I use to be able to use wireless linksys but lately received unauthorized access errors at a few websites and now I can't use linksys wireless, is there anyway to reopen port?
I have a problem with my Colubris installation: As long as the accesspoints are on the same subnet,...
(More)
I have a problem with my Colubris installation: As long as the accesspoints are on the same subnet, everything works fine. When I put an accesspoint on a different subnet, the wireless users (connection via an employers SSID eg. only authentication) get an IP-address and all, but cannot access anything on their LAN. Any ideas? :)
I have an edimax ar7265wna wireless adsl/modem router that came bundled with an edimax wireless pci...
(More)
I have an edimax ar7265wna wireless adsl/modem router that came bundled with an edimax wireless pci card. The problem I have is that my 2 pcs will only connect if I dont have wpa activated. I have turned off the firewall but that didnt help. my os is win7
i am using IBM ThinkPad T40 Laptop, my wireless netwotk not connected at my home (D-Link DR615...
(More)
i am using IBM ThinkPad T40 Laptop, my wireless netwotk not connected at my home (D-Link DR615 Access Point). but beside thia location my wireless working fine. kindly help me out of this . Thnx Hafeez
