Question about Compaq Presario 5000 PC Desktop
Heat sink fell off processor
I have a Compaq Presario about 3 yrs old. It was stored in a closet for about two months and when I retrieved it to set it up, I could hear a rattle inside. I removed the cover and saw that the heat sink had fallen off the processor. Closer examination revealed the sink was held on wth a spring lever, hooked on the ends and the hooks looped through a pair of small hoops on the motherboard. The hoops approx 1/4'' wide resemble a minature croquet hoop, and one of these had pulled from the motherboard allowing the heat sink to fall. There is also some dry residue from some sort of adheisive or thermal conductive compound on both surfaces of the sink and processor. Is there a product I can purchase to repair this. I have Artic Silver 5, but it has no adheisive qualities, and I belive I am in need of something like an epoxy or superglue.
  • 63 Answers
Go to your local Staple,Radio Shack or Best Buy and get a new heat sink and fan assembly, if you are lucky it will thread through the motherboard so you can reset it onto the processor chip. DO NOT PUT SUPERGLUE ON THE PROCESSOR.
AND DO NOT RUN COMPUTER WITHOUT HEAT SINK AND FAN IN PLACE OR ELSE>
Posted on Dec 23, 2008
Compaq presario a928ca laptop has overheating problem laptop overheats within a minute & we cant put it on table also we need to put some support below so that air can pass below it.
The first thing I would do is open the case and remove the fan and heat sink for the processor. You will probably find a little "radiator" looking device clogged with dust bunnies. Clean it out good with canned air and reinstall it. Be sure to clean the processor and heat sink then reapply heat sink compound. Clean all your fans and, with the case open, power up and look at all your fans. Are they all spinning at full power. If not, replace them. Reassemble the case. You should be good.
Mar 20, 2014 | Compaq Presario A928ca Laptop Lcd Screen...
How to compaq 6400 bios slow
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
Hope these tips will help.
Feb 06, 2014 | HP Compaq nc6400 Notebook
When i turn on my pc all seems well for about 5 secs then the heatsync fan and the tower fan stop moving and at that point my video card fan starts spinning 5 times faster what would cause this
Following are the reasons for overheating, just take care of these things::
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
If such problems occurs due to internal errors then i would suggest to perform a full computer scan with pc optimization tool like PCFresher for an instant fix.
Feb 18, 2013 | Compaq Presario CQ5110F (NP185AA ABA) PC...
Heatsink
INSIDE A COMPUTER OR THE HEAT SINK FOR YOUR COMPAQ COMPUTER?
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer. Processors are very finely engineered components that are not repairable. But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer. Just check with HP/Compaq for the correct and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the cover. Lay the computer down flat. If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs. Examine the processor assembly. The processor is a square chip that is covered by a metal heat sink with fins. A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard. Two clips usually secure the heat sink assembly to the top of the processor. Gently press down and slightly away on the flat end of a clip to release it. Avoid using a screwdriver to release a clip; a slip could scratch the motherboard. Release the clips and gently remove the assembly. The heat sink should separate, leaving the processor behind in the chip holder. Clean the bottom of the heat sink. Use a paper towel and a dab of solvent cleaner to remove the old thermal paste. Set the clean heat sink aside. Lift up the lever to unlock the old processor and remove it from the pin mount. Insert the new processor chip. Align the pins on the processor to the "cut off corner" or dot on the pin mount. The processor should drop into the pin holes easily. If the processor won't drop in easily, check the pin alignment. Once the processor is inserted correctly, pull down the lever to lock in the chip. Apply thermal paste to the bottom of the heat sink. Apply enough paste to cover the area of the small gray rectangle on top of the processor. Apply the paste with a spreader made from a piece of flexible plastic. Spread the paste evenly to a thickness of two sheets of paper. Check the heat sink mounting alignment and lower the heat sink onto the top of the processor. Reinstall the mounting clips. Reattach the heat sink fan to the motherboard if necessary. Plug in the computer and monitor and boot. If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully. Shut down again and replace the exhaust fan hood. Close up the computer and reboot. Hope this helps.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=thermal+paste
Jan 19, 2013 | HP Compaq Presario SR5610F Desktop PC
Bad processor on my hp compaq
Just check with HP/Compaq for the correct size and speed of processor for your motherboard before purchasing a replacement.
Remove the cover.
Avoid using a screwdriver to release a clip a slip could scratch the motherboard.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps
Nov 11, 2012 | HP Compaq dc5100 Microtower PC Desktop
Compaq presario sr5000 no power but fans run cd rom opens and closes.
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Oct 27, 2011 | Compaq Presario 5000 PC Desktop
My Compaq Presario F730US keeps overheating the fan does not run properly what docking station do you recommend me to buy
I would recommend cleaning out the vents and geatsink grills with compressed air. I would then remove the heatsink unnit and replace the thermal grease on the heatsink and processor. Most laptops do not need any additional cooling if thier heatsinks are free of dirt, dust and debris. The compressed air can be bought at office supply chains. Just use short bursts of air and clean all the compartments including the cd tray. Just make sure to power down the laptop first and remove the battery.
Oct 05, 2009 | Compaq Presario F730US Notebook
HP Compaq Presario V6048CL Overheating
take a look into bios and see if the the there is a shut down at certain temp is set ..to be sure ..just restore to factory defaults ...but the best thing is to take a look and remove the settings if there is a temperature limit on ..cpu temp...its risky ..but I always let it without limit and it was ok ...
Aug 02, 2009 | HP Compaq Presario V6048CL Turion 64 X2...
Fan constantly running,have comp presario sr1420nx about 4 yrs
If blowing the dust did not help your only other options are replace the fan or replace the heat sink with a newer one that incorporates a quieter fan.
Jun 09, 2009 | HP Compaq Presario SR1420nx...
Notebook fan is not running and unit is getting hot
the fan vanes are clogged, this may happen if you have pets or live in a humid region.
take the unit apart and remove the heat sink from the laptop, get some arctic ice silicone from a computer store and apply an amount equal to that of a piece of rice to the processor (after first cleaning of the residue on the heat sink), clean the cooling vanes out and replace the heat sink, put the unit back together and the unit should not overheat again.
The silicone will take a while to solidify to the optimum.
Apr 02, 2009 | Compaq Presario C700T , Pentium Dual-Core...
Compaq Presario 5000 PC Desktop Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
