Question about HP LaserJet 3030 All-In-One Printer
No printing or copying all of a sudden
My HP laserjet 3030 was working just fine and all of a sudden the paper comes out blank in the printing or copying function. I restarted the computer and the printer, it didn't solve the problem. Please help!
  • julia92263 Dec 25, 2008
    Master:
  • 416 Answers
It can be one of the following:
Defective laser shutter
EP Cartridge Support missing or damaged
Toner cartridge
Transfer roller voltage
Developing bias charge
Drum ground path
Laser scanning cable assembly
So I would try from checking toner. If it wont help it can be one of the reasons above
Most probably the laser shutter isn't opening, due to some parts
getting out of position. So removing covers off, inserting
and removing the cartridge a few times can tell you what should be moving and what isn't moving any more.
Good Luck
Posted on Dec 25, 2008
  • HP Master
  • 13,433 Answers
Try this semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Dec 23, 2008
  • 40 Answers
If you are using a parallel port connection, try a USB connection instead and reinstall the drivers.
  • 535 Answers
U need to refill your toner or your printer cardige its will be empty
Posted on Jan 16, 2009
  • 124 Answers
Just try to remove ink and make sure it is full add another cartrige and try again hold down button to test print it is green hold down 3sec and test print hope this helps
    Scholar:
  • 80 Answers
1>First of all open the top cover and remove the toner cartridge and shake it gently and refit it properly and than try to take copy .
2> If still problem continues than check for the paper usage done since toner is refill or replaced. that mean check for the toner is empty or not. if more than 2500 prints has been taken from this toner than you have replace the toner by new one.
3>For any other assistance kindly feel free to revert.
  • HP Master
  • 2,386 Answers
It seems the toner may be ended. repace it and try again.
hope it will solve the problem.
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
Hp laserjet 3030 won't copy, indicating that memory is low and to press enter. A blank page then prints.
Press cancel and then retry that job. If it still fails, try to print something else. If that job works then you are going to have to print the other job on a different printer. It is sucking up too much memory.
Sep 21, 2010 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 Paper is crushed from top right edge when printing/copying. How can/do I fix this? I have used a heaver weight paper and it does not get crsuhed, however the print is usually smudged right...
Try reseating your Ink Cartriges first then try printing to see if the error still appears, if it does try reinstalling your printer drivers... make sure you check your printer cables if they are conencted properly to your computer after reseating the cartriges.
May 21, 2010 | HP LaserJet 3030 All-In-One Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Paper jam
this is paper related problem use good barnd paper and working fine
Jul 23, 2009 | HP LaserJet 3030 All-In-One Printer
LASERJET 3030 PRINTS ONLY 1 COPY VISTA 64
Well go to file and click on Print... this will bring up a list of settings for your printer as well as the list of printers. There you should see a box that says number of copies.
Dec 03, 2008 | HP LaserJet 3030 All-In-One Printer
LaserJet 3030 only makes one copy
in stead of trying to fix hp's **** equipment throw there junk away and dont buy hp equipment
Nov 22, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
219 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
