FixYa.com
Tags:
Rollei 66 Dual P 35mm / Medium Format Slide Projector
I Cannot load or remove slide carousel Properly,...
By Joey2 - usenet poster
I Cannot load or remove slide carousel Properly, what can it be?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 25, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
the slide tray will not lower/install in projector.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 08, 2005
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
turn on the slide projector, then push down on the black lever on the side of the projector. Make sure to rotate the carousel to zero.
This Problem Also Relates To: Sony VPL-CX85 3000 Slide Projector Braun Novamat 330 AF 35mm LKM Straight, CS Straight Slide Projector Braun Novamat 353 AF 35mm LKM Straight, CS Straight Slide Projector Kodak Ektapro 9020 35mm 140 Slides Rotary Carousel, 80 Slides Rotary Carousel Slide Projector Kodak Ektapro 7020 35mm 140 Slides Rotary Carousel, 80 Slides Rotary Carousel Slide Projector Kodak Open Box BC-4401 Slide Projector Kodak Open Box BC-4601 Slide Projector
Can you Help with these Slide Projectors problems?
Slide Projectors
VW golf mk 1 gti cab 1989
I have been having a problem... Answer This...
Slide Projectors
Manual
I'm looking for an instruction... Answer This...
Slide Projectors
vw golf gti anniversary p reg
engine not fireing when turning... Answer This...
Repair Service
Find Slide Projector Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
