Question about Microsoft LifeCam VX-6000 Webcam
I can't seem to get the audio to be in sync with video
I look like I'm in a foreign film badly dubbed
  • rcaldera Dec 29, 2008
    I have the same exact problem. The audio isn't in sync with the video. The audio is ahead of the video.
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 23, 2009
I have a sylvania Video cassette Recorder/DVD player. Is there a way to copy the DVD onto videotape with this machine
It depends what you want to copy on DVD on to the video. If it's a commercial film, forget it! The machine/disc will have macrovision on it which will destroy any transfer to video. Otherwise there should be a button that says copy or dub that will let you record other types of DVD recordings to tape. But I can't understand why you would want to as the loss of quality would be bad.
Dec 06, 2009 | Sylvania (SRDD495) DVD Player/VCR
Recording Audio via the Audio In/Out
If this camera come with a Mic input or audio in put you will need to use a seperate amp. or use internal.
Dec 06, 2007 | Panasonic AG-DVC30 Mini DV Digital...
Sony hxd890=rec from hdd to dvd
I had the same problem but changed the recording mode to SP. I used a DVD-RW to high speed dub a two hour film and a documentary about a holiday island.
Both dubs were perfect.
Dec 23, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Downloading video
The video recorded on some camera's may put the audio out of sync. That sounds like what has happened with you. If the sync is always off by lets say 2 seconds, you can fix this by taking the video footage into an editing system and you can align/adjust the audio to match the video. It's a little extra work, but it will fix you problem.
Good luck
Jan 15, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Audio out of sync
You may want to put the audio into the microphone-in of your laptop and make menu selections for audio via that line-in port when recording. I found as well that the audio sync was out of whack when trying to have it go with the video through the EasyCap..
Nov 24, 2007 | Ulead Videostudio 8 for PC
Sherwood RD-6500 sound problem
I don't have this particular reciever, but I think the dubbing feature mentioned can be turned off. If that can't be done I suggest moving the components in video and audio 2 to the 3rd available one, it shouldn't have that feature. That's all I can offer.
Jul 18, 2007 | Sherwood RD-6500 Receiver
Can I "audio dub" onto my Viewcam?
No. The audio and video signals are recorded on the same track, thus not allowing audio dubbing to be possible on our 8 millimeter Viewcam.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Microsoft LifeCam VX-6000 Webcam Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
