Question about HP Compaq Presario V2000 Notebook
Computer won't turn on
Hi, i mustn't have turned off my computer correctly last time i shut it down - hence the battery is drained. i plugged in the power supply and my computer will not turn on. i have tried a similar power supply of the same output and nothing happened then either. my computer contains my university life so this is kinda freakin me out. if anyone could help at all it would be greatly appreciated! Thanks!!
  • chels smyth Apr 11, 2007
    it is a laptop...how do i connect it to the main socket without the battery plugged?? sorry i am very very dumb wen it comes to computers! thanks for your help tho!! xox
  • 60 Answers
Whether youve got power issues or not all is not lost your data should be safe. the battery can be removed usually from the underside or side of the laptop with a lock that needs to be slid across. click on my profile and theres people recommended who can help you out.
Posted on Apr 12, 2007
  • 57 Answers
Is it a Laptop? If yes, try to connect it to the main socket without the battery plugged with your machine. If it is a desktop, the only option that you have it to change the PSU or the SMPS.
Posted on Apr 10, 2007
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
My acer Aspire 5741 won't charge beyond 37%
Let your computer run out of battery(until it shuts down) then plug it but don't turn it on... let it charge for about 2 hours. Post here if it worked.
Aug 29, 2011 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Hi, I have an Asus PRO50G laptop. Last night I shut it down before going to bed and assumed that it had shut down successfully, but when I awoke I found that the laptop had run itself out of battery while...
Since the battery totally ran out, hence, now you require to charge it back up kindly do not try to switch on your laptop any more unless you have left it on charger for a minimum of 8 hrs. In case even after charging for 8 hrs it is doing the same thing i.e. logging off then, press f8 key while booting up and from the selection select last good known configuration and hit enter. That will fix everything. In few cases it's also f10 button hence try both f8 and f10.
Mar 19, 2011 | ASUS Computers & Internet
Nokia 95 8GB is dead
man check it with a new battery or it may b posible that ur fone s/w is crrupet which need to reinstall by a expert .
Dec 25, 2009 | Cell Phones
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Laptop turns off when charger is plugged in !!
Charger is bad and is not putting out the correct voltage which causes the computer to shut down. Battery probably isn't much good either if it only lasts for one hour. Get new batter and charger. Ebay'ers will help you find one cheap.
Jun 01, 2009 | HP Pavilion dv1000 Notebook
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
HP Compaq Presario V2000 Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
