Question about Samsung YP-U3 MP3 Player
Can't on it
This device connect the computer but it couldn't show hard drive. it can't be charge
Install wmp11 and try again...
Posted on Dec 27, 2008
My USB flash drive is not recognizable in any computer. It shows up in device manager as unknown device. But in "My Computer" the drive does not show up at all. There is no light that is blinking o
Download the driver from Verbatims web site. Reinstall it some of thos flash drives are really picky. You might have had a virus and it wrecked the connection. Reinstall the driver from Verbatim.
Feb 07, 2014 | Iomega 34610 320 GB USB 2.0 Hard Drive
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
Will not turn on but shows power and charging lights
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jul 17, 2012 | Toshiba Computers & Internet
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
In management ,I can show a 500GB disk but couldn't read or write , couldn't active . I couldn't take out my data .
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 08, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
For some reason my Hitachi external hard drive is not showing up on my computer. I know that once i plug it in it should show up on My Computer but its not. What should I do??
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
My hard drive will not show up on my laptop when I plug it into the USB port. My USB ports work fine on the laptop because other devices show up. My hard drive was working before, but now it won't show up...
* the USB cable
* the power-adapter
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Dec 11, 2010 | Western Digital My Book Essential 1TB...
Lost all files without deleting?
you need to do system restore ASAP, reboot your computer and keep clicking on F8 tell you get to a window that gives you manay options including restore use this to restore yoour computer to the dday that you start working on your files or before. if that did not work post your findings and we will give you another way to get access
Sep 28, 2009 | Maxtor Shared Storage II 2TB Network...
External Hard Drive connected but hidden !!!
Connect it to your computer.
Right click on my computer and select Manage
On the left side click on Disk management.
Now on the right side, look around and see if you spot the external drive there.
What do you see there?
Also look into device manager, then look for anything with ! or ? yellow marks.
May 03, 2009 | Western Digital WD Passport 250GB Portable...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Samsung YP-U3 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
