Question about Sentry Fireproof Safe
Sentry Safe A3819
You see...I have this safe which I can't really open. I don't really know why, I have the code and the key but when I use them on the sentry safe the handle won't budge. It's been 5 years since I last used this and the manual is currently lost because it's also in the safe. Please help I need to get something in there.
    Scholar:
  • Sentry Expert
  • 170 Answers
It could also be a faulty battery pack. call us at if you need one
at http://www.a1-locksmith.com/index.html
Posted on Aug 02, 2010
    Master:
  • 416 Answers
Go to
http://www.sentrysafe.com/customerCare/OwnersManuals.aspx
Find your model (pobably in safe for business)
And download the manual
Good Luck
Posted on Dec 23, 2008
  • Grigory Zyryanov Dec 24, 2008
    Please explain what is going wrong
    There is clear explanation how to reprogramm the safe in the manual. You said you have lost the manual. I have sent you a reference.
    http://www.sentrysafe.com/pdfs/OwnersMan...
    There are 3 possible ways to unlock and access the safe:
    1. Factory code
    (Found on the front cover of this guide.) You can always
    open the safe by entering the pre-set 5-digit factory code.
    This code cannot be deleted.
    2. User code
    If you prefer to employ your own code, you can program
    the safe to open using a 5-digit user code of your choice.
    3. User pin
    If you wish to give someone else temporary access to the
    safe, you can program a 5-digit user pin that can later
    be erased.
    Programming the user code
    NOTE: One (1) user code is allowed.
    If this is not working you cantry to reprogram the safe
    Programming user pin
    NOTE: One (1) user pin is allowed.
    To add:
    1. Press the Prog key 2 times.
    2. Enter your 5-digit user code.
    3. Enter the 5-digit user pin of your choice.
    To delete:
    3. Enter 0, 0, 0, 0, 0.
    NOTE: If your safe does not appear to be working, please
    check batteries before calling Sentry Customer Care.
    So why you marked my answer as inappropriate
    Please let me know
    Good Luck
2 Suggested Answers
SOURCE: Sentry A3819 Manual
I have the A3810 and you have to hit the program button, enter the original code that came with the safe, then enter your new code and you should be able to reprogram it.
Posted on Feb 03, 2008
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    Says code error
    How To: Open A Locked Sentry Safe If You Forgot ...
    ? 5:21
    https://www.youtube.com/watch?v=Mr8QrvVAtuI
    Jul 15, 2014 - Uploaded by TipsNNTricks
    I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
    ' Sentry® Safe ' Lost Your Combination
    https://www.sentrysafe.com/.../Lost_Your_Combination
    Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
    opening a electronic safe forgotten the lock code ready to ...
    www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
    InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
    How to Crack a Safe (with Pictures) - wikiHow
    Jan 10, 2016 | Home Security
    Have key and code...safe will not open
    Sentry Safe not unlocking - YouTube
    ? 0:36
    https://www.youtube.com/watch?v=4mbtSUAoS6w
    May 8, 2013 - Uploaded by 1diazsantana1
    When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
    Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
    idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
    May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
    Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
    Lost my Manual for my sentry A3819 safe
    From the manufaturer's web site:
    http://www.sentrysafe.com/pdfs/OwnersManuals/505748.pdf
    Aug 25, 2009 | Sentry Fireproof Safe
    Can't open combo/key sentry safe.
    You need to contact Sentry, they will send you an emergency unlock code.
    Number in US is 1-800-828-1438.
    See also:
    Lost combination or keys
    Replacement Keys and Combinations
    Sentry Safes Key: 2 Replacement keys for sentry fire safe
    Apr 18, 2009 | Sentry Fireproof Safe
    Dear all i'm intending to buy a new sentry safe model a3819 i can not find the specifications is tha safe is fire proof
    Sentry Fire-Safe. Water resistant safe with a five digit programmable lock & tubular ley, key rack, seperate compartment for small items, door pocket, multi-position shelf & two trays. Suitable for both home & office with a 2-hour UL fire rating. (1)
    Hope this helps
    Nov 26, 2008 | Sentry Fireproof Safe
    Sentry A3819 Manual
    Jan 30, 2008 | Sentry Fireproof Safe
    Sentry Fireproof Safe Logo
    2,147 people viewed this question
    Top Sentry Home Security Experts
    Hannah Johnson
    Level 1 Expert
    ray012965
    Michael Galve
    Michael Galve
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
