Question about Dell Inspiron B130 Notebook
Inspiron B130 won't boot
My inpiron b130 won't go past the windows logo. So the computer goes past the Dell Logo to a screen where it says that there was a problem and gives me choices to restart the computer like normally, or safe mode. When I click on normally turning it on the screen goes to the windows logo. Then after it loads it goes to a black screen. Then it just stays black.
  • 2 more comments
  • yogirlmizros Dec 23, 2008
    it won't let me work on any of the safe modes. When I click on the safe mode it starts to work than freezes midway through the process.
  • joykarunanit Jan 11, 2009
    My inpiron b130 won't go past the windows logo. So the computer goes past the Dell Logo to a screen and then goes to a black screen.... help!!!!
  • Anonymous Jan 29, 2009
    try this to test close the screen when it is still running and open up again and see if it comes back if it does than it might be backlight problem.....
  • Anonymous Mar 28, 2014
    When I switch on just a black screen,with advent logo. Then error code 0xc0000185 comes up, please help!!
    Can't restore to pervious date etc as laptop won't boot up past logo screen
    Genius:
  • 2,785 Answers
Plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Posted on Dec 23, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Dec 23, 2008
    then you have to reload or repair your operating system
My dell inspiron b130 boots up but monitor is black
After your laptop boots up into windows, hold down the Fn key and as your doing that press the F8 button that should switch the output from the vga connetor to the LCD screen on the laptop.
If you still don't get video then you'll have to reseat the LCD cable from the back of the LCD screen to where it connects to the motheboard.
If you still don't get video then its either going to be a bad LCD or a bad motherboard.
Aug 09, 2009 | Dell Inspiron B130 Notebook
Dell B130 boots but nothing on screen and no boot up sounds
If you are seeing an shadow image on the LCD and you have video on an external monitor, then the LCD backlight has failed. The LCD will need to be replaced
I googled B130 LCD's and they generally run $125 to $200
Jan 13, 2009 | Dell Inspiron B130 Notebook
BOOTING PROBLEM DIAG PROBLEM
What os you running? it booting problem or diag problem? If you can access windows desktop, you can try use Microsoft Bootvis to Diag your boot problem and Bootvis also can optimze you boot time :)
Sep 26, 2008 | Dell Inspiron B130 Notebook
B130 Monitor Problem
Connect an external monitor at the back of your laptop and see if the display is fine. If the display is fine with the external monitor, it means to say that there's something wrong with your LCD's backlight. You may have to contact Dell Technical Support to check if your system is still under warranty.
Thanks! :)
Aug 26, 2008 | Dell Inspiron B130 Notebook
Dell inspiron b130 won't boot up.
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Apr 09, 2008 | Dell Inspiron B130 Notebook
Display goes haywire...
The easiest solution is remove the hinge cover and check if the LCD cable got cut.
http://tinyurl.com/oyrzt
follow the following instructions to replace display assembly
http://tinyurl.com/hbk5x
You can also run diagnostics.. power on and press F12 on dell logo slowly 5 times
Select diagnostics and follow on screen instructions.If the LCD fails its time to replace the same.
Apr 06, 2008 | Dell Inspiron B130 Notebook
Screen will not stay on
The first thing to check is the LCD or Screen inverter. It is a small board that at the bottom of screen. You have to open up the plastic part of the screen or LCD. Usually this part goes bad.
I am sending you a link of a sample from ebay,
http://cgi.ebay.com/NEW-DELL-Inspiron-1300-B120-B130-LCD-INVERTER-CARD_W0QQitemZ170147223708QQcmdZViewItem
I hope that can help you.
Feb 28, 2008 | Dell Inspiron B130 Notebook
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
575 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
