Question about Fisher and Paykel GWL11 Top Load Washer
Smart Drive - GW511
Dear Sir, I have got a F/P Washer Machine GW511. The pump seems out of control as we can't control from control panel. As soon as the machine is plugged in power point, the pump is working and pump water out while all indicators on control pabel are off including power button.
Your kind help would be very appreciated
Tom
    Habit-Forming:
  • Fisher and P... Expert
  • 194 Answers
Your main control board has a fault and will need to be replaced.
Posted on Oct 14, 2017
  • 3 Answers
SOURCE: F&P GW511
Try just unplugging the machine for a while....letting the circuit board clear any "memory". I worked for me with a spin cycle issue.
Posted on Oct 14, 2007
ngfam1
  • 639 Answers
SOURCE: reset button
Friend,
ngfam1 At your service!
With an error code the only way to find to repair this is,
Try first unplugging the appliance and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
Like I used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I refered you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
ngfam1
  • 639 Answers
SOURCE: Smart Drive 703-strange noise during wash cycle
Sounds like the belt and or a pulley !
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
1(800) 905-9505
Posted on Sep 02, 2008
aborcass
  • 2651 Answers
SOURCE: fisher and paykel smart drive 503 top loading washing machine
while under the lid there should be a tech sheet, explaining varions flashing light codes and there respective fixes for each instance, replacing tha switch(out of bal switch) seems like a good start though. cant remember if jumping it out will help, might be looking for a break in the line rather than continuity through it
Posted on Nov 02, 2008
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
Fisher and Paykel Smart Drive Pride 5.5 washing machine will not pump water out...makes a beeping noise when trying to pump water out.
I own and have repaired my smart drive washer. The water pump is very simple to remove on these machines. Unplug the machine and drain as much water from it as possible. There's a small plastic locking tab on one side of the pump. Gently pry it away from the body of the pump and twist the housing until it comes free from the metal pump housing anchor plate. Unplug the pump from it's connection and remove it. Found a guide that should help you -
How to Drain Washing Machine That Won Empty Cares Appliances
Oct 12, 2018 | Fisher and Paykel Washing Machines
Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Jun 08, 2008 | Washing Machines
How do you remove pump from smart drive?
undo the back panels
pump will be below the drum
Apr 29, 2016 | Washing Machines
Fisher and paykel aquasmart fault 235
Try cleaning the INLET and the outlet valves, it is possible that the filters are blocked. If not check the wiring harness from the panel, check for moisture within the panel, if so use a dryer to warm off and test. Please estimate before any parts are replaced.
Jan 20, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
3rd 4th and 8th light + beeping every second on fisher & pakel smart drive model gw511
its one of tricky ones,because its one of two faults, both are board faults question is which one so you need two replce and try it if tht doent work replace the other one
Jul 11, 2012 | Fisher and Paykel Fisher & Paykel Washer
The smart drive washing machine leaks when in use what can I do? Thanks
if it is leaking from bottom check pump if it looks like rusty looking then its been leaking for a while replace pump if you keep operating washer with it leaking from pump it can also short out control board
May 13, 2011 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 9 just turns off after first rinse cycle
Hi there
Can you smell an awful burning smell as the machine shuts itself off, if this is the case then it sounds like the pump motor has overheated and and activated the over temp shut off on the smart drive 9 this causes the motor controller to cut out it will come back to life once the pump has cooled down or has been replaced.
only way to solve the problem is to replace the pump. to replace the pump, first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it, take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off putting the new pump on is as easy as taking it off.
Hope this helps
Nick
Aug 16, 2009 | Fisher and Paykel Fisher & Paykel Washer
GW709 MACHINE SMART DRIVE LOAD 7.5
hi
if it washes ok but won,t spin it canbe pump if it has not pumped all the waterout or can be lid switch,but normally they won,t wash if the lid switch is funny so i would be checking the pump side of things
cheers grantsreps
Aug 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Smart Drive 701 w/machine not spinning
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the right side of the bottom of the machine, but with the unit tipped on its front it's easier to remove it through the back than through the bottom of the washer. Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Good luck!
Sep 16, 2007 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
111 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
jimorris77
shaun taylor
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
