Question about Frigidaire FRS23R4A Side by Side Refrigerator
HELP ME FRIDGE IS BUZZING AND LEAKING
My side by side frigidaire is buzzing and only cooling slightly, there is a puddle at bottom of freezer in front. Can anyone direct me to what theproblem and is this somehting my husband and I could fix? Thank you
  • christy Prine Apr 10, 2007
    I meant the freezer part the other side is working fine.
    President:
  • 1,462 Answers
Could mean ice build-up on evaporator - buzzing could be fan jammed asgainst ice. remove back panel of freezer to check. this would usually affect fridge as well however
Posted on Apr 10, 2007
Frigidaire freezer making humming noise name brand frigidaire
if it is like a buzzing sound and it is a two door unit, and you can tell from which side the noise comes from, either from the fridge or freezer side please do so-
Also, has it begun to take longer to cool ? if so, you may have a worn out evaporator fan that sometime in the near future will be ruined and the fridge will not cool as needed
If that is so, the replacement part runs somewhere between 35.00 to 50.00 plus the technician labor cost to replace it
Aug 19, 2014 | Refrigerators
Yesterday started hearing a buzzing sound from the fridge. Came home today with a pool of water in the kitchen coming from the fridge. Opened the freezer, ice is melted and inside is relatively warm....
I would check for a bad starter relay first unless you can verify that the sound is comming from the compressor. How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 16, 2009 | Frigidaire PLRS267ZAB Side by Side...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Freezer losing temp... intermittent buzzing sound
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Nov 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
Sep 04, 2008 | Frigidaire FRS26R4A Side by Side...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Freezer Buzzing
thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Apr 02, 2008 | Refrigerators
bad reley or bad compressor proably the ladder if it has an indian on it
Feb 15, 2008 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
193 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
