Sony 42 inch hd tv built in 2002, will it accept a blue ray playe
Will it accept a blue ray player
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Posted on Dec 29, 2008
Gurudristi
  • 98 Answers
SOURCE: onkyo tx-sr806 reciver ''DTS HD''
hdmi connection between player and AVR. Right?
I am sure you would have also done the first time setup and set all the 7 speaker as well as the subwoofer thru your auto or manual speaker set up and that the reason you are getting Neo6.
On your Receiver, please also check the format of the digital input signal thru "Displaying Source Information" Press the [RECIEVER] button, and then press the [DISPLAY] buttorn repeatedly to cycle thru the available information.
a).. If the information shown say that DTS - ES Discrete, DTS- Matrix, DTS -HD and so on.... then we need to check as to why the receiver is not accepting the signal.
b).If the information shows otherwise and a 7.1 signal is not availalbe, then its possible that the source(in this case the BD player/or the recording is not sending the required signal).
lets take the case (a). In this case if you have all the 7.1 set up in place and you are getting the required signal , then you can assign a default listening mode to each input source that will be selected automatically when you select each input source.
Press [RECEIVER] button followed by [SETUP] button and enter listening mode setup, use up , down buttons to select the input source that you want to set and press [ENTER].
then use [up], [down] button to select the signal format that you want to set.
then use the [[LEFT] and [RIGHT] buttons to select a listening mode.
When you are finished, you can press [SETUP] again.
The above is with experience with ONKYO AV Receivers. In case you have a problem , please let me know so that I can go thru the SETUP menu of your particular receiver i.eTX-SR- 806.
HOpe the above sort out. DO let me know.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
freetek
  • 5568 Answers
SOURCE: is the sony trinitron 23 inch tv hd ready
You will need a model number before anyone can even do any research.
In general, there were never many CRT (picture tube) TVs made with the required ATSC tuner and if your set is 5+ years old, it isn't compatible with digital reception.
Posted on Oct 11, 2009
tvtek
  • 1284 Answers
SOURCE: HDMI problems with 40'' bravia
The HDMI reciever board in the TV is bad and will need to be replaced. You should have a technician look at it so they can get the correct part number using the model number and the TV's serial number too.
Posted on Nov 11, 2009
  • 336 Answers
SOURCE: I just bought a Blue Ray player but my surround
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Posted on Nov 21, 2009
Why won't my blue-ray player DMP-BD87 play blue-ray disc's any more?
Because Blue-Ray isn't what it's cracked up to be. In fact no TV studio will even consider using one.
Mar 07, 2015 | Panasonic DMP-BD871 Smart Network Blu-ray...
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
My sony wega 42" rear
it depends on the type of blue ray player you buy some only have hdmi output others have standard rca - yellow - red - white this is the one you need
Dec 29, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony blue ray wont play hd movies.
Does your player load the blu-ray menus?
Mine wouldn't until I updated it's firmware.
You can find the firmware upgrade for Sony BDP-S300 players here.
I hope that helps.
Oct 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
How do I get from 480 to 1080p on my tv? I have an HD box on my vizio 42 inch tv but my channels are still showing 480?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
Sep 12, 2009 | Vizio Televison & Video
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Can not get my new 42 " Aquos TV to work with my new blue ray DVD
A blu ray player will play on any television. The television might not however have the highest resolution to display the full capability of a blue ray. That being said, the blu ray player may be faulty the connections may be incorrect. I would recommend running an HDMI cable from the A/V out on the blu ray to the HDMI input on the TV. GOod Luck
Dec 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I think a connectivity problem with tv and dvd player
dvd playes or hd dvd players will not play blu ray diskd you must have a blue ray player to play blu ray disks
Dec 02, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Code to enter on remote
i have new Sony BDP-S350 Blu-ray disc player. i want to connect it to E-net and some other devices, Camcoder, Pc, Laptop. i have got all HD ready cables,
I want to use the Universal Remote from my Sony Bravia LCD 42'' TV and Blu-Ray. can anyone help me?
thanks
omar
Dec 10, 2007 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
