Question about Maytag MDB7100AWB Dishwasher
Maytag dishwasher, no power, then flashing lights, now no power.
I have a maytag dishwasher model number mdb4651awb. Less then 1 year old. About 2 weeks ago it just stopped working out of the blue. Loaded it and pushed start but no power. Then today I was walking through the kitchen and there were lights lit and flashing on the control panel. I pushed cancel and all lights went off. Tried to push start but nothing happened. About two minutes later there were more lights flashing. I pushed cancel but nothing happened. Then a moment later all lights went off. They haven't been back on. Can't use the dishwasher. What could be the problem?
  • 2 more comments
  • ncroxygirl Jan 07, 2009
    Same problem with mine :(
  • jordanx5 Jan 21, 2009
    Mine worked one day, stopped the next. The lights that indicate which cycle have selected light up but when I push start nothing happens. Tried turning off breaker and then powering back up but no luck.
  • Anonymous Mar 19, 2009
    no power on. Was ok 2 days before.
  • Tonya Perry Oct 16, 2013
    and mine.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Posted on Mar 08, 2009
This worked for me, my wife made fun until I pulled the paper and ran some diagnostics, the thing started!!
Posted on Dec 08, 2009
  • Judy Hughes
    Judy Hughes Nov 09, 2015
    Thank you so much...we are now looking at the long paper...this is a pain in the mane!
How do I reset my mdbh955aws?
DIY fix your Maytag dishwasher on the cheap - Instructables
InstructablesLast week my 1.5 year old Maytag dishwasher suddenly quit working. ... of its own for about 2 years, shutting off the breaker to reset it has worked until today.
Oct 19, 2015 | Maytag Dishwashers
The control panel is flashing a L. What does this mean?
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
Just bought a 4 year old maytag 300 quiet series and hooked it up all front buttons light up when you push what you want but will not fill with water. Goes to cycle where water should be spraying around...
Sounds like an internal timer malfunction.
Maytag Customer Service: 1 (800) 344-1274 U.S.
Try to find your model # and serial number if not out of warranty before called.
It sounds as if your machine needs to be inspected by a service repair agent in your area. Maytag can lead you to an authorized local repair man.
Oct 08, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My dishwasher (Maytag MDBH965AWQ quiet series 300 was purchased in May 2006 (making it just a little over 4 years old). The handle broke on it initially and now the control panel has gone out including...
Well Kathy, you may be in luck. There has been a safety recall on your model of dishwasher and Maytag will give you a considerable allowance to replace with another Maytag. You may contact them at 1-800-544-5513 with your model and serial number and they will give you instructions on how to obtain your new dishwasher at a deeply discounted rate and all the details.
Sep 11, 2010 | Maytag Dishwashers
I have a Maytag MDB6701AWS dishwasher and the control panel is not responding, the lock light is on but it is not responding. I had the same problem less than a year ago and they said the control panel was...
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Aug 08, 2010 | Maytag MDB6701AW 24 in. Dishwasher
Maytag MDBtt60awb will not start. Power definitely at dishwasher as panel lights are on, however "start" button does nothing. Dishwasher is less than 2 years old. The panel buttons eventually turn off. ...
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Apr 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601A)
While I am not directly aware of the controls on the dishwasher I'd unplug it for a minute or two to see if the control reboots (for lack of a better term) I've seen many electroic devices that on occasion have this type of problem and simply taking the power from it may correct it.
I hope this helps,
Aug 22, 2009 | Dishwashers
Maytag MDB7100AWB Dishwasher Logo
3,437 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
