Question about JVC AV-27720 27" TV
The only thing that happens is the red power light is flashing
The television worked fine until four weeks ago. the screen would go to a straight line horizonally across the screen and we would beat on the side to reinstall the picture. one day it got so bad it finally went blank and silent. the red on/off switch still flashes after it has been turned on and won't quit until it is unplugged. please help.
  • 89 Answers
The Vertical output ic is bad la7832 also has an open resistor in power supply off of pin 7 the ic.
Root cause is probably the zener diode next to the IC itself MTZJ75
Posted on Mar 12, 2009
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
Lamp was replace, color wheel and now ballaster and now the bulb does not turn on.
the only thing I can think of is be sure the safety switch on the back is not your problem.
Mar 12, 2012 | Televison & Video
Red and green lights blink but why is there nothing on screen?
The voltage from the power adapter is critical for proper operation. If it's a little low, the lights will work, but not the picture. There are capacitors on the motherboard that fail with age, so check them too.
Dec 08, 2011 | Swann Communications DVR4-Alert Video...
ONLY LAMP LIGHT FLASHING WHEN PLUGGED IN, WON'T START, NOYHING HAPPENS WHEN YOU HIT THE POWER BUTTON.
make sure the lamp cover is in good and the screw is snug just had mine open and only thing that it does is red light flash and nothing on screen......unplug power and try it then plug it back in about three or four minutes later.....hope that helps
Nov 15, 2010 | Hitachi 50VS69 50" Projection HDTV
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Turns off/on every few minutes
I would replace the Lamp. This is a common symptom when the Lamp is failing.
I hope this helps,
Skyassoc
Oct 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Red lamp lite flashes along with power light.......
That is definitely the Light Engine (also referred to as an optical block) Very expensive.
Dec 31, 2008 | Sony KDF-E55A20 55 in. LCD Television
Black screen
my sony kp-61hs30 displays that there is no siginal, also the red indicator light blinks when the power is turned on but goes out i have dirct cable pluged into the set and up until about a week ago it worked fine.All of the other tv's in my home work fine so i don't understand what the problem is . I have a dvd player connected to the set and it works great for viewing dvd's please assist with me with some trouble shooting points
Jan 24, 2008 | Sony KP-61HS30 TV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
