Question about Sony STR-DE545 Receiver
EQ hookup???? I would'nt have bought this unit if I knew you couldn't hook up a EQ. No tape 2 (monitor) outputs. Any body know how to hook up other wise?? thanks
  • 67 Answers
Yes I do! I hade the same problem so went to radio shack and got tow Y -RCA splitters with one male and tow female works great!!
Posted on Dec 23, 2008
  • Xtremeroofin
    Xtremeroofin Dec 23, 2008
Where is pre out im having trouble hooking up amp and eq
You have to use the TAPE 2 (or monitor) on the receiver. It will take two sets of RCA cables. Both the receiver and the EQ will have an input and an output.
  • Run the output/REC (from TAPE 2) to the input on the EQ.
  • Then, run the input from the receiver (TAPE 2 again) to the output on the EQ.
The EQ will have another 2 sets of RCA jacks to hook up a second tape deck (because you used the jacks on the receiver for the EQ). You don't have to hook anything to these if you don't want to, or don't have a second tape deck.
The receiver will have a monitor button, which most of the time is labeled as TAPE 2/MONITOR. Select whatever input you want to use (CD, Tuner, Aux, etc.), then press the MONITOR/TAPE 2 button. When that is on, the EQ will be in the audio chain - you'll be able to use the EQ to adjust the sound. If you turn the MONITOR off it will take the EQ out of the audio chain - the EQ settings won't affect the sound.
Keep in mind, the EQ will also have a button to select the TAPE 2 input. If you have a second tape deck hooked up to the EQ, this is how to use it. Make sure that the tape input is off on the EQ, if you aren't listening to that second tape deck.
Mar 09, 2016 | Audio Players & Recorders
Install a equalizer to Teac Ag D9100 Receiver
From what I can tell (from photos), you'd hook an equalizer in the Tape 1 or Tape 2 path, where the EQ takes its input from the receiver's Tape 1/2 output and the EQ feeds its output to the receiver's Tape 1/2 input. When you want to switch the EQ into the signal path, you just push the tape monitor button for whichever tape path you hooked up.
Jul 24, 2015 | Teac Audio Players & Recorders
Audio Output Non-Functional
Yes. Take it to the repair shop and have yet outputs fixed.
Feb 27, 2017 | Kenwood Stereo Graphic Equalizer - Ge-76
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
I have a Pioneer VSX-D308 reciever and I have a EQ. How do I hook it up to this reciever?
I only know of one way to do this and here it is:
1. Plug your tape deck's output (cassette or R2R) into the EQ's "Line In".
2. Plug the EQ's "Line Out" into the Receiver's "Tape 1 Input".
3. Now plug the Receivers "Tape 1 Output" into the Tape Player's "Line In".
4. You have now made an "FX loop" for the Tape Deck. Now you just have to put the Tape Deck on "Tape Monitor".....put the Receiver on "FM"..... and turn on your favorite FM station and you will hear the FM Receiver THROUGH the tape deck's "Monitor Send" AND the EQ.............set EQ to taste....... and BINGO.......DONE!
Enjoy,
SKYNETRP
Jun 09, 2011 | Pioneer VSX-D308 Receiver
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Apr 15, 2010 | Denon Audio Players & Recorders
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
How do I connect a Marantz EQ 140 to a Marantz MR235 reciever through tape one (tape monitor) I am not confident that I have it hooked up correctly because I get music when the eq and tape monitor are on...
Dear driver800,
Don't you just love it when when someone who knows less than you do tries to answer your question? Why is it people who know little waste everyone's time with suggestions like "read the book"
On the back of your Marantz MR-235 you will find the RCA phono jacks marked Tape 1 Monitor Output these connect to the jacks labeled input on your EQ 140. The corresponding jacks labeled Tape 1 Monitor Input connect to the jacks labeled output on the EQ 140.
QED
Russ
Jul 28, 2008 | Marantz Audio Players & Recorders
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Sony STR-DE545 Receiver Logo
113 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
