Question about Sewing Machines
?How to disengage flywheel on my sewing machine
Trying to load the bobbin, can't figure out how to disengage the flywheel. The wheel does not loosen. I have bobbin on spindle for loading, but cannot get mechanism to lock into place for loading the bobbin. Sears Kenmore model 158.17033 (built in the 70's, I think)
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
Posted on Jan 23, 2009
bargainbox
  • 1388 Answers
SOURCE: bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Posted on Sep 01, 2009
caroldon
  • 17130 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
Disengaging mechanisam for bobbin winding Foot pedal not sensative enought
Foot pedal carbon brushes may be worn and need to be replaced.
Nov 12, 2015 | Sewing Machines
The flywheel will not turn on my elna su air electric machine
do you mean that you can't unlock the inner wheel on the flywheel to disengage the clutch? Grasp the outer flywheel and using a plastic mat for removing jar lids, get a good grip on the inner clutch wheel, then turn it towards you.
Jul 28, 2014 | Elna Sewing Machines
I can not turn the wheel to fill my bobbin. And the needle keps trying to sew and after awhile the safety beep comes on how do I fill it.
1. Read and understand your manual. The days of turning a wheel to disengage the needle are pretty much LONG GONE.
2. Put your bobbin on top of the machine where it goes and slide it to the left. This action disengages the needle.
Mar 15, 2013 | Singer 7468 Mechanical Sewing Machine
Stop motion wheel frozen. undid screw but not able to unscrew or loosen wheel. Machine runs beautiful except for this one issue.. how can I get this motion wheel off or loosened so that I can wind bo
As a simple fix you can buy a freestanding bobbin winding device online, this will wind a bobbin for most machines so is a simple fix and can be used at any time.
You may also want to remove the top cover of your machine and oil internally, it may help with the fly wheel issue. There is an oiling diagram for a White 1510 on this page http://www.sewusa.com/Sewing_Machine_Repair/White_Sewing_Machine_Maintenance/White_1505_1510.htm
If your machine top cover looks similar and you can remove it then certainly use this image as a guide to oil in the arrowed places, then manually turn the flywheel towards you gently to spread the oil. Use a good quality clear machine oil, or Triflow if you can, it has silicone in and doesn't dry out and leave sticky residue like a mineral oil can over time.
From reading the manual for the White 1418 on the Singer website, it looks like you hold the outer part of the flywheel and turn the inner knob towards you to disengage the clutch for bobbin winding. Is that what you have described above?
If you don't have the manual you can download it from the Singer Instruction manuals page, link is http://www.singerco.com/accessories/instruction-manuals, then type W1418 into the search field and click "search" then wait for the screen to load, you'll get a "Free download" icon on the right after a few seconds. Click this and wait again for the pdf file to download, it will take a bit of time depending on your internet speed.
Nov 14, 2011 | White Sewing 1418 Mechanical Sewing...
Elna supermatic bobbin winder will not spin
is clutch disengaged? inner wheel in flywheel, hold flywheel and turn inner knob towards you to loosen. put bobbin on spindle and move to right to wind. if youve done this already and no joy then bobbin winder tyre may have perished. try www.sewingpartsonline.com to buy new one
Oct 13, 2011 | Sewing Machines
This morning, I successfully used my White 423R for the first time in many years! However, now I need to fill a bobbin, and I can't seem to "disconnect the Hand Wheel from the sewing mechanism by...
Do you have manual for your machine? If so, does it specifically instruct disengaging the needle action by turning the inner wheel? Some machines disengage the needle when you flip up or press the bobbin winder. If your machine instructions include turning the inner wheel, be sure you are turning it "counter clockwise" to loosen. It could be that it is frozen. Of course, your machine probably needs lubrication but I doubt that will help with your particular issue. Perhaps applying heat from a handheld hairdryer to the wheel will help loosen it, or you need someone with more strength.
However, you can pick up a standalone bobbin winder (SideWinder) avlb at JoAnn's or Amazon for ~$30 that is either electric or battery operated. It's a handy little gadget since it allows you to quickly wind multiple bobbins at a time, saves wear and tear on your machine, plus allows bobbins to be wound without having to unthread the sewing machine.
Nov 10, 2017 | White Sewing Sewing Machines
Needle not going up and down but power getting to the machine
Check your manual for the bobbin winding steps for your particular model.
On some machines there is a knob in the center of the hand wheel that is loosened for bobbin winding - this also disengages the movement of the needle. Tighten for sewing.
There may be an additional step, such as moving the bobbin winding pin to the right or the bobbin winding wheel to the left.
Apr 06, 2010 | Bernina Sewing Machines
Just bought my used Bernina 1010;it was sold to me
Heat the wheel with a hair dryer to loosen. If this does not help, you will need to visit an authorized Bernina dealer.
Jul 21, 2009 | Bernina Sewing Machines
Elna su flywheel won't turn.
On the Carina SU there is a button on the flywheel to disengage when winding a bobbin. Be sure this button is pushed in.
Mar 05, 2009 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
312 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
