Question about GE Profile Spacemaker II PEM31 Microwave Oven
Microwave won't turn off
When the time has expired and I open the oven, the microwave often continues to run.
  • 1 more comment
  • mjnielson Dec 27, 2008
    The microwave has no turntable.  The inside light and internal cooling fan continue when I open the door.  Thanks.
  • Anonymous Jan 24, 2009
    I have a Panasonic inverter genius sensor microwave oven 2003 with the same problem. When the time has expired and i open the door, and it continues to run.
  • William Miller
    William Miller May 11, 2010
    Is it actually still cooking?
    Or is it just that one or more of the following is still running:
    - turntable
    - inside light
    - internal cooling fan
  • GE Master
  • 9,098 Answers
Sorry I forgot to ask you for the model number.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Or see http://www.microwavedisplay.com/doorsw.txt
You can often find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is not there, please reply back with your brand and model number.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 28, 2008
Is the micowave dangerous and can we fix it.
You did not provide the make or model of your Microwave, but to give you a generic answer, it sounds like there may be an issue with the control board or the door interlock switch.
If you are not familiar with repairing electrical appliances, it is best to call a qualified service company or bring it to a repair center. If you have the owner's manual or user guide, there should be some information about where and how to have the oven serviced.
Jul 21, 2015 | Microwave Ovens
Fan running when door open
measure this test and use the multimeter for fix it. GOD BLESS YOU
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Nov 08, 2013 | GE JVM2070 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
The oven won't turn off, am leaving the door open so that it won't run
well pull the plug or go out to your circutbraker/fusebox and finde the fuse for the oven.
then you coud try to open the oven (while its not connected to power!) and try to clean the swiches...
Jun 12, 2012 | GE Advantium 120 Convection/Microwave Oven
After time has expired and food removed,oven continues to run when door is re-closed
you most likely have a micro switch, or monitor switch behind the control panel that has failed or contacts have shorted, you may want to replace all of them if you don't know how to test them
Feb 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
My microwave continues to run, (turntable and exhaust), when the door is opened.
all microwaves have 2 safety switches at least... but these are tied to a set of relays that turn it on, my bet is a sticking or stuck relay because you unplug it right and plug back in its not running?-relay ... if always runs driver transitors.
Dec 27, 2007 | Panasonic NN-T990SA Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
GE Profile Spacemaker II PEM31 Microwave Oven Logo
818 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
