Question about Sunbeam 275 Watts 2369 MixMaster Series Hand/Stand Mixer
Broken Mixer Release Trigger,
The Mixer Relaees Trigger (the spring clasp that locks the mixer to the stand) has come off and I tried to get it back on to no avail. Does anyone know how to reattach the part? Thanks!
3 Suggested Answers
  • 8 Answers
SOURCE: Need turntable stand replacement...
Hi, I just noticed your posting as I was looking for a replacement switch for mine. Mine has only been used once (never leave your mother and sister alone, to make candy divinity, with a mixer they don't know how to use :). I was hoping to be able to replace the part I need so I can use it, but if you could use it more, please let me know. My email is ronandcarisa@yahoo.com I have NO idea what the procedure is for something like this, I don't think it goes against the Terms of Use, I would just like to help if I can.
Thanks! Cris
Posted on Jan 18, 2008
SOURCE: Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
Posted on Nov 04, 2008
Sunbeam 2366 mixer - how do you replace the mixer release trigger
Look at this site.
http://sunbeammixmasterlove.tumblr.com/tagged/manuals#.U50ef5Qs6So
Jan 01, 2014 | Sunbeam 2366 MixMaster Series Hand/Stand...
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
The flat mixing paddle is stuck in the mixer and can't be removed from the socket. It turns but when I pull it would not come out.
Here's what really happens. The hook has a shaft screwed into it with bayonet fittings that lock into the mixer. The shaft has a locknut where it screws into the hook. If the locknut becomes loose then the shaft can screw in too far making removing from the mixer almost impossible. Try to get a slim wrench onto the locknut and loosen it off enough to allow the hook to be unscrewed. After the hook comes off, move the locknut down the shaft until the whole assembly can be removed from the mixer. Re-attach the shaft to the hook making sure that the exposed portion of the shaft is long enough to allow for easy removal from the mixer. Tighten the locknut and you will never have the problem again.
Oct 20, 2010 | Cuisinart SM-55 Stand Mixer
Trying to replace carbon brushes on Kitchenaid stand mixer. I understand from reading other answers that there is a ''right way'' to insert them. I did not pay close enough attention in removing old ones...
Check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Keep turning the brush until you have the shortest amount of spring sticking out when you press it in all the way then slowly release pressure on the end of the spring. You will know when it is in correctly since the difference in length is noticable. The curvature on the front of the brush must line up with the curved surface of the armature which runs from the front of the mixer to the rear.
Apr 18, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Mar 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
KichenAid mixer parts problem
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
has a diagram of the locking mechanism item 9. The screw you removed was probably item 8. Look at the parts and you should be able to figure out how to get it back together.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
Jul 25, 2009 | KitchenAid K45SS Classic Stand Mixer
Good Luck
Dan
Oct 08, 2007 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam 275 Watts 2369 MixMaster Series Hand/Stand Mixer Logo
100 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
